1968 door panels - NCRS Discussion Boards
1968 door panels
  • Thomas P.
    • April 28, 2010
    • 37
    1968 door panels
    Just curious to know what anyone has found marked on the inside of their 1968 door panels .Also does anyone know who G.M contracted with to make the panels and where they were located?
  • Terry B.
    • August 31, 1999
    • 607
    Re: 1968 door panels
    Hi Thomas,
    Here are pictures of my door panels. I believe them to be original, however, others may know better. How do your's compare?
    Terry Buchanan
    Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
    Corvettes Owned:
    1977 Coupe
    1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
    2003 Electron Blue Coupe
    2019 Torch Red Grand Sport Coupe
    • Thomas P.
      • April 28, 2010
      • 37
      Terry Thanks for the pictures. Do either of your panels have any writing (numbers,names,symbols) on the back of the panel?
      • Blair K.
        • September 27, 2012
        • 170
        My early model '68 has the name of "Liz" written in black grease pen on the backside of one of the panels. I forget what the stamped dates are. I will check and report back. Will also check for any other markings or symbols for you.
        Regards.
        • Thomas P.
          • April 28, 2010
          • 37
          Blair Thanks My driver's side panel, like yours, has the name "Pat" written in black crayon and the date "Feb 2 1967"(I think a mis-stamp) stamped on it. However, my passenger side has three different types of writing in three different materials,yellow and black crayon and black grease pencil.Also there are several sets of numbers and an unusual symbol.The panel is stamped "Feb 1 1968" Also there is the name "Peg" as well as what appears to be "Quinnesec Mich."In addition there is a marking which is either "9.88 67" or L.88 67. I know my panels are original and look like they haven't been off before as the factory adhesive and vapor barriers were still intact. Pretty strange .
          thanks again
          • Blair K.
            • 170
            Hello Thomas
            Now you got my curiosity up. I am going to check my panels (s/n 5338) this weekend for other markings. I also still have my original door panels from another early model '68 that I use to own - s/n 400245. I know both sets are OEM originals. I will let you know what I find.
            Cheers. BK
            • Terry B.
              • August 31, 1999
              • 607
              My Passenger side panel is dated Jan 12 1968 and has the name Rose. The Driver side panel is dated Nov 16 1967 and has the names Dot and Joyce and the number 12-D. The car has a built date of mid Dec of 67. It would appear by the date that my passenger side panel is a very early replacement panel. Looks the same otherwise. I would not expect such a close date for a replacement panel to the build date. I wonder what caused the panel to need replacement within the first 30 days of being new.
              Terry Buchanan
              Corvettes Owned:
              1977 Coupe
              • Curt S.
                • April 30, 1975
                • 64
                I have a passenger side panel with M-B Oct 18 1967. Towards the top of the panel there is a crayon C written. Hope this helps. Curt
                • Patrick N.
                  • March 10, 2008
                  • 954
                  Similar to Terry, one of my doors has Rose- or Rosie on it with a build date of March 7th. Its very cool to find those personal marks made so locg ago.
                  • Thomas P.
                    • April 28, 2010
                    • 37
                    Terry Thanks for the info. I also had a 68 with a driver's side door panel a few months after the build date .A retired parts man from a local dealership told me that there were many customer complaints about the panels and he recalls ordering a "bunch" of panels for replacement under warranty. Also, one of the quality issues that prompted car and driver to refuse to test drive the 68 was the driver side panel coming off the door.
                    Thanks again Thom
                    • Thomas P.
                      • April 28, 2010
                      • 37
                      Patrick Thanks So far we have Liz.Pat,Peg.Rose.and Jill. I wonder if these ladies were inspectors or the actual constructors of the panels? What is the name on your panel written in? (crayon ,grease pencil, etc.) How close is the date on your panel to your build date?
                      Thanks again Thom
                      • Blair K.
                        • 170
                        Hello Thomas,
                        I am trying to post pics of my door panels for you - but for some strange reason I am not allowed to do so. I will try later.
                        Regards.
                        • Thomas P.
                          • April 28, 2010
                          • 37
                          Blair Thanks for trying . Some of the writing on my panels was so light it could hardly be seen. I ended up using a blacklight to make it visible.
                          • Blair K.
                            • 170
                            Hello, Thomas
                            I had no problems in taking the pics - all the markings showed up great on my end. I am just having a problem uploading them to this Forum (for some strange reason). I am going to try uploaded them again.
                            • Terry B.
                              • August 31, 1999
                              • 607
                              Hi Blair,
                              I had a problem too when I first tried to load my pictures on this thread. I thought I should try to load pictures that I had reduced in size but they would not load. I found that the full size pictures loaded without problem. They seemed to be automatically reduced at the NCRS loading end. Not real terminology accurate but the best I can do this morning. Hope this helps or you might contact the help desk with the problem.
                              Terry Buchanan
                              Corvettes Owned:
                              1977 Coupe
