66 turn signal - NCRS Discussion Boards
66 turn signal
  • Joe R.
    • July 31, 1976
    • 4550
    Re: 66 turn signal
    William,
    You will have to purchase and replace the entire switch for the 67. It's not much of a problem and should not take more than an hour or two.
    JR
    • William F.
      • June 9, 2009
      • 1363
      Re: 66 turn signal
      Thanks, Joe, but that was what I was afraid of. 2 hours, huh? Looks like a PITA unless you can give some tips. I may just keep holding lever down. lol.
      • Peter L.
        • May 31, 1983
        • 1930
        #18
        Re: 66 turn signal
        You can also hang your arm out the window to indicate your intention to turn or some other intention.
        • Joe R.
          • July 31, 1976
          • 4550
          #19
          Re: 66 turn signal
          Pete,
          IF you keep giving out information like that how is a guy to make a living selling Corvette Parts?
          JR
          • Donald O.
            • May 31, 1990
            • 1585
            #20
            Re: 66 turn signal
            William,
            IMHO there are three options on the 1967 TS replacment
            Option 1
            After disconnecting the arced connector and removing the steering wheel, plastic column cover, horn contact, steering hub (you'll need a puller), unscrew the three attaching switch screws and pull the switch part way away from the column.
            Cut the old switch off leaving a couple/three inches of wire still attached.
            Make the same cut of the wires on the new switch
            Use solder and heat shrink tubing when splicing back together going color for color.
            GENTLY pull the old harness back down through the small column raceway cover and re-attach the new TS switch.
            Reassemble the steering wheel to column.
            About 2 hours time.
            Option 2
            Cut the wires to the switch off
            Pull the switch and harness up and away from column
            On the new switch, remove each wire with its terminal from the new arced connector.
            Slide the wire harness down through the small column raceway cover and re-attach the new TS switch to the hub and the arced connector.
            About three hours time
            Option 3
            After disconnecting the arced connector and removing the steering wheel, plastic column cover, horn contact, steering hub (you'll need a puller), remove the steering column from the car.
            Remove the upper bearing housing from the column.
            Remove the escutcheon from the column
            Remove the small column raceway cover, it snaps onto the column.
            Remove the switch connector from the escutcheon and upper bearing housing.
            Remove the switch.
            Installation is the reverse of the removal.
            On all three options:
            you will have to also remove the turn signal lever and hazard warning button for reuse. A good time to polish the chrome on both before reassembly.
            I recommend re-using the original arced connector as it is black and all the new switches have a brown connector.
            Also, while the colors codes are correct on the new switches they do not match the originals in hues.
            Plus, while you have the column out, you can clean, inspect, and rebuild and recolor the column and hubs as needed.
            I just did option 3 a few weeks ago on my 67 with standard column.
            Don
            • Donald O.
              • May 31, 1990
              • 1585
              #21
              Re: 66 turn signal
              He could try smoke signals, but someone would think he's driving a ford.
              • William F.
                • June 9, 2009
                • 1363
                #22
                Re: 66 turn signal
                Option 4. The hell with it. Hold lever down and also give hand signal. Have adult beverages (but not while driving) in the 2 or 3 hrs it would have taken to replace switch.
                Thanks, though.
                  • 15599
                  #23
                  Re: 66 turn signal
                  Thanks, though.
                  It just occurred to me to wonder how many drivers today would know what the hand signals for turning are. Those of us of a certain age know, but I doubt millennials are aware of this archaic practice. Be sure to signal with the whole empty hand.
                  When I get home this evening I will ask the resident millennial if she knows how to hand signal a turn. I anticipate an interesting conversation.
                  • Philip A.
                    • February 26, 2008
                    • 329
                    #24
                    Re: 66 turn signal
                    How would you expect millennials to use hand signal? One hand would be on the steering wheel and the other on the cell phone!
                    • Jim S.
                      • March 1, 1986
                      • 1398
                      #25
                      Re: 66 turn signal
                      That one hand on the wheel is only there when they are not texting ! Then it's just a knee !
                      Jim
