66 turn signal - NCRS Discussion Boards
66 turn signal
  • Jay G.
    Infrequent User
    • January 14, 2012
    • 26
    66 turn signal
    Need to hold down signal arm for left signal light to flash. signal cam, switch?
  • Donald O.
    • May 31, 1990
    • 1593
    Re: 66 turn signal
    switch
    BTDT
    Don
    • Jay G.
      Infrequent User
      • January 14, 2012
      • 26
      Re: 66 turn signal
      I was not sure
      • William F.
        • June 9, 2009
        • 1364
        Re: 66 turn signal
        What's BTDT? Which part is the "switch"? I have the same problem on a '67.
        • Gary B.
          • February 1, 1997
          • 7067
          Re: 66 turn signal
          William,
          It took me a bit to figure that out, but BTDT means "Been There, Done That".
          Gary
          • Donald O.
            • May 31, 1990
            • 1593
            Re: 66 turn signal
            Replace the switch. Not too difficult. If your current switch is original save the harness and arced connector, it should be black. The repops are brown.
            Don
            • Joe R.
              • July 31, 1976
              • 4552
              Re: 66 turn signal
              Jay,
              There is a arm that the lever attaches to and holds the switch on until the cam cancels it or you move the lever back. The end is broken and needs replacement. No need to replace the whole switch. Easy fix by removing the horn button, horn contact and then the steering wheel. Remove the screw holding the white plastic assembly and replace.
              JR
              • Jay G.
                Infrequent User
                • January 14, 2012
                • 26
                Re: 66 turn signal
                Are you talking about the piece that looks like a half moon shape? I believe that is the only piece you can buy for the switch.
                • Joe R.
                  • July 31, 1976
                  • 4552
                  Re: 66 turn signal
                  Jay,
                  Yes, it's half shaped and the part number ends in 015. Tomorrow evening I'll be back at the shop and send you a pic and part number.
                  JR
                  • William F.
                    • June 9, 2009
                    • 1364
                    Re: 66 turn signal
                    Please send that pic and PN to this forum. Does the PN you're going to give apply to part I can buy from Paragon,etc. or from GM, etc.?
                    • Donald O.
                      • May 31, 1990
                      • 1593
                      Re: 66 turn signal
                      Is it available from the great vendor and restorer near Little Rock, AR?
                      Nudge nudge, wink wink.
                      • Joe R.
                        • July 31, 1976
                        • 4552
                        Re: 66 turn signal
                        Here's the delayed pics and part number. The pic of the switch on the right side is one of a 64-66 only and the left side is just to show that the ends of the actuator is broken off. 63's are one year only, 67-68's are one year only and 64-66 are what is pictured on the right.
                        The complete switch including wiring for 64-66 is part number 910821
                        The actuator is part number 5957015
                        The part number for the 63 switch is 3824116
                        The part number for 67-68 is 5698520
                        JR
                        • William F.
                          • June 9, 2009
                          • 1364
                          Re: 66 turn signal
                          Joe,
                          Are these PN's GM? Will a young Chevy parts counter guy know where to look and order or will he say. "My book doesn't go back that far."? What is the name of this part?
                          • Joe R.
                            • July 31, 1976
                            • 4552
                            Re: 66 turn signal
                            William,
                            These are GM part numbers BUT the 67 has long been discontinued. Look to Corvette Central, Long Island or Corvette America for the 1967 Turn Signal Switch.
                            JR
                            • William F.
                              • June 9, 2009
                              • 1364
                              Re: 66 turn signal
                              Think I erased my intended "reply." Do I have to buy the entire switch for my '67 to get a good actuator. Can the actuator be separated from the new switch and installed on my switch without having to replace the entire switch, including threading the wiring down the steering column?
