Please critique this 1967 L79 engine - NCRS Discussion Boards
  • Gene M.
    • April 1, 1985
    • 4232
    #31
    Re: Please critique this 1967 L79 engine
    Originally posted by Donald Olson (17357)
    Are you missing the "HT" label at the rear of the rocker cover?
    Don
    No, I don't think so if it were a "HT" code the water pump pulley is wrong as well as the RH mounting brace.
    • King M.
      • December 7, 2013
      • 135
      #32
      Then it was from the factory as such. Apparently, this engine is one of the much debated c60 only l79 with deep groove cs and wp pulleys. Original owner and whom I bought from said they were never changed.
      • Bill M.
        • 1322
        #33
        Jim
        Great job! I pulled my L79 C 60 motor 25 years ago and last winter both times I left all of the C 60 parts off after installing the motor ( other than brackets ) to break the motor in. made changing plugs and inspecting all around a lot easier without the compressor in place. I am thinking about putting a vintage air system in car now. Gasp!! But the car has nothing to prove.
        • King M.
          • December 7, 2013
          • 135
          #34
          Jim oh so true! It is a challenge to change even bank plugs, but after the first time you don't forget how you did it
          • Mark E.
            • April 1, 1993
            • 4537
            #35
            Should the timing marker be orange?
            I believe they were natural/plated in later years.
            Mark Edmondson
            Dallas, Texas
            Texas Chapter
            • King M.
              • December 7, 2013
              • 135
              #36
              Mark, the timing mark is attached to the timing chain cover so it would be painted orange.
              • Mark E.
                • April 1, 1993
                • 4537
                #37
                Were they sometimes masked when the engine was painted?
                Mark Edmondson
                Dallas, Texas
                Texas Chapter
                  Mark -
                  Nope - there was no reason to mask them.
                  • King M.
                    • December 7, 2013
                    • 135
                    #39
                    So the right hand plug bracket on the back of the engine block is plated and the left one is painted? That explains what I was seeing.
                    what about the clip on the intake bolt that holds the vacuum line in place? Was it part noted silver or a black color?
                    • Gene M.
                      • April 1, 1985
                      • 4232
                      #40
                      The silver spray was only to coverup assembly "markings" that detracted from the aluminum color. The amount of aluminum color paint varies a lot from one engine to another. My experience was the vacuum line bracket phosphate was covered over pretty well to none at all. The only thing that seems to get a good coverage is the mounted thermostat housing, it's gasket, and bolts. The interface area of the manifold, cylinder head, bolts, and intake gasket also typically got aluminum color paint too.
