Is it necessary to bench bleed master cylinder? - NCRS Discussion Boards
  • Jim T.
    • March 1, 1993
    • 5351
    Re: Is it necessary to bench bleed master cylinder?
    ...and don't forget to flush with fresh brake fluid every two years or so. That prevents moisture build up and component damage.
    I use silicone brake fluid in my 1968 and 1970. Even after years of use I can see the bottom of the master cylinder cavities when fluid is checked.
    • Jim L.
      • September 30, 1979
      • 1817
      Adding to what Jim wrote, the wheel cylinder in the photo below saw only silicone fluid for the 22+ years it was in service and never once required any maintenance like flushing/bleeding the brakes. The cylinder wall is pristine.
