Radials Tires for the 66' - NCRS Discussion Boards
  • Ralph E.
    • February 1, 2002
    • 905
    #46
    Re: Radials Tires for the 66'
    Try a set of Michelin Symmetry WSW 205/75-15. The WSW is narrow, about 9/16"
    • Leif A.
      • August 31, 1997
      • 3645
      #47
      Ralph,
      The word is that Michelin no longer makes a 205/75R-15 WSW
      Leif
      • Donald A.
        • January 7, 2013
        • 239
        #48
        Originally posted by Jim Sfetko (58204)
        Here's what the Cooper Trendsetter SE looks like on a '65.
        [ATTACH=CONFIG]60685[/ATTACH]
        [ATTACH=CONFIG]60686[/ATTACH]
        hey. Thanks for the Cooper tire pics. I agree that it looks good and the cleaner side wall. I also like the side tread better than the uniroyal tire.
        • Timothy B.
          • April 30, 1983
          • 5196
          #49
          Would the uniroyal tires score better if the car got judged?
          • Jeff S.
            • July 31, 1984
            • 384
            #50
            The 'Symmetry' in 215/70-15 (near-correct diameter) is long gone, and it's too bad. I got one of the last sets in 2012. They are a great tire. White wall is a crisp 3/8" & the white stripe extends 'out' slightly from the sidewall. Perhaps there's a set lurking around somewhere.
            • Donald A.
              • January 7, 2013
              • 239
              #51
              I think if you don't have correct bias ply it doesn't matter. Same deduct. I'm no judge though
              • Edmund C.
                • April 14, 2015
                • 232
                #52
                Gents: What is a larger tire; the 205/75/R15 or the 215/70/R15? It appears that the former 205 is. For my 66, I'd like something a bit beefier than the 215/70/15s that are on there now (and that will not cause fiberglass damage).
                • John F.
                  • January 1, 1979
                  • 62
                  #53
                  Tire Sizes Explained -
                  • Edmund C.
                    • April 14, 2015
                    • 232
                    #54
                    John: Thanks a lot, this was very helpful. Question to NCRS Forum: Does a 215/75/15 fit on the '66 Corvette?
                      Edmund -
                      The 205/75-15 and the 215/70-15 are the same diameter (27.1"), but the 215/70 has a slightly wider cross-section; the 205/75 has zero risk of rubbing, but the 215/70 can rub under certain conditions (full-lock driveway entry, etc.). I wouldn't put 215/75's on my car. Folks tend to forget that the midyear tire-to-body clearance envelope ("tire flop") was designed in 1960 around a 6.70-15 tire on a 5.5" rim, and the midyear is very unfriendly to larger tire sizes and non-stock wheel widths/offsets.
                      • Donald A.
                        • January 7, 2013
                        • 239
                        #56
                        Hey all;
                        Another option.
                        While getting the tires rotated on the truck this AM I saw another option on the wall.
                        This is a Firestone Affinity 215/70/15 and the WW measures exactly 3/4" (I checked to see if avail in a 205. They said no)
                        In a 205/75 I'm leaning toward the Cooper and in 215 these Firestone's look really good. (If you are so inclined for a little more rubber on the road)
                        • Donald A.
                          • January 7, 2013
                          • 239
                          #57
                          Hey Gary, What did you end up getting and post some pics. I'm thinking Cooper Trendsetter SE
                          • Gary N.
                            • August 31, 1986
                            • 118
                            #58
                            I ended up getting the Uniroyal Tiger paws. I couldn't find a set of the Coopers locally to get a good look at them and the local dealers said that if they ordered them I would be obligated to take them. Another local dealer had the Uniroyal's and I liked their looks and the 11/16"whitewall. They look good on the car. I will try to take some pictures soon. I think the Trendsetters looked good also (in pictures I saw), so it was a matter of being able to see what I was getting at the time and the easy of availability.
                            Gary Nyland
                            1966 Black Corvette Air Coupe
                            2014 Black Z-51, 3LT Coupe
                            1955 Black Chevy Belair Gasser
                            1955 Nomad
                            • Donald A.
                              • January 7, 2013
                              • 239
                              #59
                              update;
                              I had my tire shop send in one of the Uniroyal 205/75 to compare with look with the Cooper.
                              I liked the more traditional tread of the Cooper especially on the edge. also the Cooper has a cleaner side wall. The WW is within 1/16" of each other.
                              I went with the Cooper and will post some pics of them on the KO's. Hope this helps
                              • Donald A.
                                • January 7, 2013
                                • 239
                                #60
                                As promised here are the 205/75 coopers on the 66. I really like how these turned out! Pics are not the best resolution
