Pulled instrument cluster with John Hinckley's help - NCRS Discussion Boards
  • David T.
    • April 30, 2006
    • 46
    Yesteday afternoon I pulled out the instrument cluster on my 66 using John Hinckley's article Non Luster Mid Year Cluster. I was amazed at how thorough his instructions were. Made it a lot less difficult. Would highly suggest, as John did to purchase the ignition wrench and headlamp wrench. Thanks John.
  • Joe R.
    • May 31, 2006
    • 1822
    Re: Pulled instrument cluster with John Hinckley's help
    David,
    That is good news!!! I was doing the same before I stored the car off site. I hope to get back at it this summer.
    Joe
    • Philip A.
      • February 26, 2008
      • 329
      Completely agree. I too followed the article. It made what appeared to be a very daunting task, more simple and doable. It actually seems easy after you have done it! The most difficult part of the entire job is maneuvering your body in the confines of the car.
      • Russ T.
        • May 31, 1989
        • 113
        David,
        Would you happen to know the month and year that this article appeared in the Corvette Enthusiast ?
        I successfully downloaded Part 2, but am having trouble locating part 1.
        Russ Trotter
        NCRS #15044
        • Joe R.
          • May 31, 2006
          • 1822
          Originally posted by Russ Trotter (15044)
          David,
          Russ Trotter
          NCRS #15044
          Russ,
          Here you go:
          Joe
          • Joseph U.
            • April 30, 2001
            • 241
            Do you happen to have a link for Part 2? Hopefully that gives hints on the re-installation, which I have yet to do.
            THanks
            Joe
            • Jim S.
              • March 1, 1986
              • 1408
              Joe ,
              Here you go .
              • Joseph U.
                • April 30, 2001
                • 241
                That's great Jim,
                I have the panel on my work-bench just waiting for some help like this, Now all I have to do is get the A/C vents in and then should be ready for this.
                Joe
                • Jim S.
                  • March 1, 1986
                  • 1408
                  Here are some more pics that should help make it easier still !
                  • David T.
                    • April 30, 2006
                    • 46
                    I have had virus problems with my computer so I am just getting back. Hope to start Part II of John's cluster installatation this week. I sent tach to be recalibrated and refaced. It should arrive back to me Tues or Wed.
                    • Russ T.
                      • May 31, 1989
                      • 113
                      Thanks Joe, that will help me out considerably!
                      I appreciate your prompt response.
                      Russ Trotter
                      • Dave B.
                        • April 30, 1984
                        • 248
                        You might want to check the Summer 2006 Restorer article...Mid-Year Dash Resto Tips. It also is based upon John Hinckley's fine article from the Corvette Enthusiast.
                        • Scott T.
                          • December 29, 2014
                          • 20
                          wait till you put it back that's when the fun starts hope you have hands the size of an elfs I was black and blue from my wrist to my elbows
                          • David T.
                            • April 30, 2006
                            • 46
                            Wasn't too bad. I do have small hands. I used one of those bright headlamps which allowed me to see what I was doing really well. I can only say that having John's 2 part article made it a lot easier and was also very thorough and was easy to refer to and check progress of your work. Again I say "Thanks a million, John".
                            • Scott T.
                              • December 29, 2014
                              • 20
                              just curious did you have one extra gray wire bulb, I used the pictures posted by Jim as I found them on the internet also, and it actually shows one extra bulb, maybe cars with auto trans?, I am 100 percent sure I didn't miss any spots for this thing checked several times, glade your went back in easy.
