Yesteday afternoon I pulled out the instrument cluster on my 66 using John Hinckley's article Non Luster Mid Year Cluster. I was amazed at how thorough his instructions were. Made it a lot less difficult. Would highly suggest, as John did to purchase the ignition wrench and headlamp wrench. Thanks John.
Pulled instrument cluster with John Hinckley's help
Re: Pulled instrument cluster with John Hinckley's help
Completely agree. I too followed the article. It made what appeared to be a very daunting task, more simple and doable. It actually seems easy after you have done it! The most difficult part of the entire job is maneuvering your body in the confines of the car.- Top
David,
Would you happen to know the month and year that this article appeared in the Corvette Enthusiast ?
I successfully downloaded Part 2, but am having trouble locating part 1.
Russ Trotter
NCRS #15044- Top
Russ,
Here you go:
Joe- Top
Joe ,
Here you go .Attached Files- Top
That's great Jim,
I have the panel on my work-bench just waiting for some help like this, Now all I have to do is get the A/C vents in and then should be ready for this.
Joe- Top
Here are some more pics that should help make it easier still !- Top
I have had virus problems with my computer so I am just getting back. Hope to start Part II of John's cluster installatation this week. I sent tach to be recalibrated and refaced. It should arrive back to me Tues or Wed.- Top
Wasn't too bad. I do have small hands. I used one of those bright headlamps which allowed me to see what I was doing really well. I can only say that having John's 2 part article made it a lot easier and was also very thorough and was easy to refer to and check progress of your work. Again I say "Thanks a million, John".- Top
just curious did you have one extra gray wire bulb, I used the pictures posted by Jim as I found them on the internet also, and it actually shows one extra bulb, maybe cars with auto trans?, I am 100 percent sure I didn't miss any spots for this thing checked several times, glade your went back in easy.- Top
