Pulled instrument cluster with John Hinckley's help - NCRS Discussion Boards
  • David T.
    • April 30, 2006
    • 46
    Re: Pulled instrument cluster with John Hinckley's help
    No. Did you leave out the bulb that goes on the back of the ignition switch or the shrouded bulb holder that clips onto the cigarette lighter housing. If that's it you should be able to replace either of those without pulling the cluster all the way out
