70 bolt ID help - NCRS Discussion Boards
70 bolt ID help
  • Bill L.
    • February 1, 2004
    • 1403
    70 bolt ID help
    I have the bolt pictured below but have no idea where it belongs.
    Anyone have any thoughts on where it belongs on my 70?
    Re: 70 bolt ID help
    Thanks, Bill[ATTACH=CONFIG]56647[/ATTACH][ATTACH=CONFIG]56648[/ATTACH]
    What's the thread size and the length (from bottom of head to end of bolt)?
    • Bill L.
      • February 1, 2004
      • 1403
      Re: 70 bolt ID help
      Hi John,
      3/8"-16 x 1-1/2" long
      Thanks, Bill
        • 43284
        Re: 70 bolt ID help
        Hi John,
        Thanks, Bill
        Bill------
        Seems like I've seen these "NAT" headmarked bolts used for bumper, radiator support or frame horn attachment.
        • Bill L.
          • February 1, 2004
          • 1403
          Re: 70 bolt ID help
          Bill------
          Hmm-I wonder if it might be a bolt that holds the front bumper on to the body on the side. GM 427559.
          Bill
          • David L.
            • July 31, 1980
            • 3310
            Re: 70 bolt ID help
            Bill
            Bolt # 427559 appears in my 1969 Chevrolet Parts catalog (10/68) in Gr. 8.900 and is described as hex head bolt 3/8"-16 X 2" (300-M).
            Dave
            • Bill L.
              • February 1, 2004
              • 1403
              Re: 70 bolt ID help
              Dave
              Hi Dave,
              Hope you are well.
              That rules out that location. The bolt is clearly 1-1/2" long.
              Bill
              • David L.
                • July 31, 1980
                • 3310
                Re: 70 bolt ID help
                Bill,
                I believe that the 67-72 fuel pump bolts, GM # 3778526, are 3/8"-16 X 1 1/2" with an attached lock washer but the head of this bolt usually has a ridge around the perimeter.
                Dave
                • Bill L.
                  • February 1, 2004
                  • 1403
                  Re: 70 bolt ID help
                  Bill,
                  Dave
                  I checked and the original bolts are there for the fuel pump and the bolts are the indented hex head .
                  Bill
                  • Rich P.
                    • January 12, 2009
                    • 1361
                    Re: 70 bolt ID help
                    Bill 1-1/2 3/8-16 could be AIR Pump bracket to intake manifold. The outer bumper bracket bolt you thought is a grade 8. Rich.
                    • Bill L.
                      • February 1, 2004
                      • 1403
                      Re: 70 bolt ID help
                      Hi Rich,
                      Hope you are well. 70 does not have an air pump on L46.
                      Good thought.
                      Thanks, Bill
                      • Dallas K.
                        • March 1, 2003
                        • 58
                        Re: 70 bolt ID help
                        How about the bolts that hold the gas tank straps at the rear cross frame.
                          • 43284
                          Re: 70 bolt ID help
                          Dallas------
                          Those were all-thread bolts. They had no un-threaded shank.
                          • Bill L.
                            • February 1, 2004
                            • 1403
                            Re: 70 bolt ID help
                            Thanks Dallas.
                            I bagged and tagged the bolts holding the gas tank straps and they are reinstalled.
                            I was thinking it kind of looks like an intake manifold bolt. However all mine were reinstalled and have an A head mark.
                            This is really stumping me.
                            Bill
                              • 3419
