photo.jpgMy upper pass. seat seems to sit back farther than others I have seen in photos. Do I have the wrong seat Back maybe? (hopefully not) It just hangs on the hooks. Seems it should be closer to the chrome like the the drivers side.
54 passenger seat
Re: 54 passenger seat
Guy, Is it possible your seatbacks are reversed? I'm not up on '54's, but I've reversed the seatbacks on my '59 once in error.
I think it was after I did my 2nd or 3rd set of carpets, I forget.
If I recall, the telltale is this.....On the seatback, along the side where it meets the center partition(glove box on later years), the vertical side of the seatback is the "wide" side. The outer vertical side, is narrower, and should face outward.
I suppose you could possibly have two "Lefts", as another possibility. Hope not. If you remove them and look at the frames you could tell.
Rich- Top
there is a RH and a LH
there is a relief at the top where your shoulder is to clear the conv top bracket/area
In the photo - something is off
Either the seat was not built correctly - it should be flush with the water fall
is it a "real" 53-55 seat back frame ?
something is not correct......1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
1957 Corvette - FI 3 sp - Black and Silver- Top
Thanks for the looks guys. I really dont know if its the correct back or not. My guy did it correctly and its shaped the way its supposed to be. Maybe a later model seat? The driver side is correct in every way. Is the back supposed to sit in those rear prongs on the floor? The bottom seem to sit in there pretty good. Thanks for the help.- Top
Can you take some more photos of the seat back
Back side1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
The seat backs dont seen as thick as they should be. Maybe another model yearphoto 3.jpgphoto 1.jpgphoto 2.jpg- Top
there is def something wrong
Looks like the backing is missing
The springs shouldnt be right up against the foam....
See how much red material is wrapped around - there shouldnt be that much material.1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
Hi Guy, Attached are some pix of my passenger seatback with original upholstery still attached. VIN 1814. Let me know if you need any measurements.Pete
1954 Corvette #814
1957 Corvette #646 -- FI, 3-speed- Top
