54 passenger seat - NCRS Discussion Boards
54 passenger seat
  • Guy M.
    • November 1, 1993
    • 500
    54 passenger seat
    photo.jpgMy upper pass. seat seems to sit back farther than others I have seen in photos. Do I have the wrong seat Back maybe? (hopefully not) It just hangs on the hooks. Seems it should be closer to the chrome like the the drivers side.
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11345
    Re: 54 passenger seat
    Guy, Is it possible your seatbacks are reversed? I'm not up on '54's, but I've reversed the seatbacks on my '59 once in error. I think it was after I did my 2nd or 3rd set of carpets, I forget.
    If I recall, the telltale is this.....On the seatback, along the side where it meets the center partition(glove box on later years), the vertical side of the seatback is the "wide" side. The outer vertical side, is narrower, and should face outward.
    I suppose you could possibly have two "Lefts", as another possibility. Hope not. If you remove them and look at the frames you could tell.
    Rich
    • Dan D.
      • November 5, 2008
      • 1323
      Don't know what is wrong Guy, but it is not correct. Trying to remember what my 54 looked like, but it was not like your pic. It was even.
      -Dan-
      • Chris S.
        • January 1, 2000
        • 1068
        there is a RH and a LH
        there is a relief at the top where your shoulder is to clear the conv top bracket/area
        In the photo - something is off
        Either the seat was not built correctly - it should be flush with the water fall
        is it a "real" 53-55 seat back frame ?
        something is not correct......
        1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
        Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
        1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
        1957 Corvette - FI 3 sp - Black and Silver
        • Guy M.
          • November 1, 1993
          • 500
          Thanks for the looks guys. I really dont know if its the correct back or not. My guy did it correctly and its shaped the way its supposed to be. Maybe a later model seat? The driver side is correct in every way. Is the back supposed to sit in those rear prongs on the floor? The bottom seem to sit in there pretty good. Thanks for the help.
          • Chris S.
            • January 1, 2000
            • 1068
            Can you take some more photos of the seat back
            Back side
            • Guy M.
              • November 1, 1993
              • 500
              The seat backs dont seen as thick as they should be. Maybe another model yearphoto 3.jpgphoto 1.jpgphoto 2.jpg
              • Chris S.
                • January 1, 2000
                • 1068
                there is def something wrong
                Looks like the backing is missing
                The springs shouldnt be right up against the foam....
                See how much red material is wrapped around - there shouldnt be that much material.
                • Guy M.
                  • November 1, 1993
                  • 500
                  Thanks Chris, anyone have a pic of the backside and how thick it should be?
                  • Peter R.
                    • June 19, 2011
                    • 233
                    Hi Guy, Attached are some pix of my passenger seatback with original upholstery still attached. VIN 1814. Let me know if you need any measurements.
                    Pete
                    1954 Corvette #814
                    1957 Corvette #646 -- FI, 3-speed
                    • Guy M.
                      • November 1, 1993
                      • 500
                      Well Peter I sure appreciate the pics. Looks like my guy left out the burlap. Is the seat about 8 inches deep?
                      • Peter R.
                        • June 19, 2011
                        • 233
                        I just went out to the garage and measured at thickness of about 6 inches.
                        Pete
                        1954 Corvette #814
                        • Guy M.
                          • November 1, 1993
                          • 500
                          Thanks Peter, I appreciate. Are you restoring your car?
