72 Tank Sticker - NCRS Discussion Boards
72 Tank Sticker
  • Kevin G.
    • February 1, 2005
    • 1076
    72 Tank Sticker
    Hi all,
    I'm researching a tank sticker, early 1972, and hoping to find some to compare. Can anyone share their sticker, any vehicle identification number before # 2300?
    TIA
    delvalncrssec@aol.com
  • Michael G.
    • March 2, 2008
    • 485
    Re: 72 Tank Sticker
    I have a 71' (Dec. 70' build date) if it helps.
    • Kevin G.
      • February 1, 2005
      • 1076
      Re: 72 Tank Sticker
      That's very kind of you Michael, Thank you. However that's a little bit earlier than my research project.
      Perhaps, I should be more specific with my question?
      Does anyone have a build/tank sheet with the key codes stamped in reverse, if viewing the face side, from a 72 Corvette with a vin number before #2300? A snapshot would be helpful!
        • 3415
        Re: 72 Tank Sticker
        Hi Kevin,
        In M.F.Dobbins 68-72 book there's a picture of a Corvette order copy for a very late 71 car with an expected date of production of 7-10-71. Page 235.
        It appears it MIGHT have the key codes….they're printed backwards and located below the last option specified in the "Option No." column….half in that column and half in the "Type" column.
        Might what I'm seeing be what you're looking for?
        • Edward M.
          • November 1, 1985
          • 1916
          Re: 72 Tank Sticker
          I believe that I have the tank sticker for 72 car #2300. I don't have the car (never did), but I got the tank sticker from a previous owner that was going to throw it out
          • Kevin G.
            • February 1, 2005
            • 1076
            Re: 72 Tank Sticker
            Hi Alan, Yes, that is exactly what I am referring to! However, in the fourth edition of Mr. Dobbins book, I find this on page 265? So, would it be safe to assume every sticker had these codes on them? It was my thoughts that these codes didn't begin to appear until the 72 model year? They do appear on my 5/10/72 built LT-1 sheet. Now, if someone could help, showing these codes on early 72 sheets?
            Hi Ed, It would be great if you could post a copy or PM one if you prefer?
            Thanks!
            • Warren F.
              • December 1, 1987
              • 1516
              Re: 72 Tank Sticker
              Kevin,
              The key codes did not show up on Corvette Order Copy sheets with the beginning of the 1971 model, but began showing up in March 1971.
                • 3415
                Re: 72 Tank Sticker
                Hi Kevin and Warren,
                I just looked carefully for any sign of the key codes on my mid January 1971 Corvette Order Copy and Window Sticker; not even a hint of anything.
                The dealer did put the key codes on the Bill of Sale though.
                • Kevin G.
                  • February 1, 2005
                  • 1076
                  Re: 72 Tank Sticker
                  Originally posted by Warren Friedrich (12139)
                  Kevin,
                  Hi Warren,
                  Now that's much earlier than I thought!
                  I never welch on a bet, I still owe you a lunch! lol
                  Hi Alan,
                  Not only do I find the key codes located in the same area, in addition, the vin. number is also on the sheet in reverse! It's on the right side of the page. I'm wondering what sheets/pages/stickers were being "gang" typed at the same time?
                  Still looking for confirmation on early 72 sheets?
                  Edit: After taking a closer look at the sheet in MF Dobbins book, the partial vin. number can be seen faintly.
                  Thanks for the help guys!
                  • Dan A.
                    • February 1, 2004
                    • 212
                    Re: 72 Tank Sticker
                    Kevin,
                    i just bought a 72 LT1 that was built in August of 71 - #1093 I believe. It has 2 tank stickers, but the car will not be delivered until the end of this month. If you are still interested in this I will let you know after I can look at them.
                    • Kevin G.
                      • February 1, 2005
                      • 1076
                      Re: 72 Tank Sticker
                      Originally posted by Dan Agnew (41438)
                      Kevin,
                      Dan,
                      Big help! Yes, I'd like to have a peak at it.
                      • Ralph S.
                        • February 1, 1985
                        • 935
                        Re: 72 Tank Sticker
                        I have the tank sheet for 1Z67L2S500868 says date produced 8-25-71 on the sheet Engine number V0813CKY axle number ABW182E2 trans number P2M05B
                        • Edward M.
                          • November 1, 1985
                          • 1916
                          Re: 72 Tank Sticker
                          Here is a copy of 72 tank sticker for VIN # 23200.
                          • Monte M.
                            • January 1, 1991
                            • 687
                            Re: 72 Tank Sticker
                            I have a very clear picture of my very clear tank sticker. What specifically are you looking for. If it is indeed the key code part of the sticker, let me know and I will send a copy of the tank sticker over to your regular e-mail. I actually have the key code blown up in some pictures and reversed so you can read it.The key code is stamped in reverse on mine. Monte
                              • 3415
                              Re: 72 Tank Sticker
                              Hi Monte,
                              For my 71 the code is four characters… a digit, a letter, and then two digits. One set for the door/ ignition key and one set for the glovebox/ spare tire lock.
                              For instance….4B56 and 5C44
                              Note that the characters are spaced so the small hole didn't obliterate one or both of the center characters which would have made the 'punch-outs' useless.
