69 column - NCRS Discussion Boards
69 column
  • Denny J.
    • November 1, 2000
    • 244
    Jeremy I will do
    What I can to help sorry
    I kind of thought you were 14 yrs old kidding me.
    OK were are you in the dismantel.
    • Denny J.
      • November 1, 2000
      • 244
      Re: Jeremy
      Lets do this on line this will be fun and others can jump in if they want.
      We may want to change info on the early years with you.
      Also don't say to many bad things about C3
      We feel your pain. Lets go.
      Denny72
      • Jeremy Hedges
        Re: Jeremy
        I like the cars, just not working on them. Not enough experience. I have the cam pulled out and I can see where the cylinder goes into the column, at least the outline in potmetal. The only thing I see that I have depressed is the rod that goes down to the electrial switch halfway down the column. Am I missing somethin else to release the lock cylinder, Do I have to have the key in it to work?
        Jeremy
          • 11698
          Re: Jeremy
          Did you check out the link above to all the info on the steering columns?
          Just checking.
          Patrick
          • Denny J.
            • November 1, 2000
            • 244
            Re: Jeremy
            put the key in turn the cylinder counter clockwise
            Battery is disconnected.
            • Jeremy Hedges
              Re: Jeremy
              I must have missed that post to the link earlier, now I have that link and printed it out and I am going to the shop. I do not have the key. Thanks again everyone. I will inform you of how it goes.
              Jeremy Hedges
              #31711
              Hedges Corvettes
              www.hedgescorvettes.com
              • Harmon C.
                • August 31, 1994
                • 3228
                No Key?
                Jermy
                The key must be in the run position to remove the lock. If you have no key that is not covered in my manual.
                Lyle
                Lyle
                  • 15645
                  Re: No Key?
                  Lyle's right -- no key no worky
                  Why no key?
