Correct vacuum hose tape 69 and heater hoses - NCRS Discussion Boards
  • Jon H.
    • January 1, 1999
    • 150
    Re: Correct vacuum hose tape 69 and heater hoses
    It goes around the check valves. also the t fittings. Also up front by the headlight actuators. I can send you some pics if you need some off my car.
    • Jon H.
      • January 1, 1999
      • 150
        • 11644
        Note, also, that there are two types of tape, and the clear tape is not used for all years.
        The clear "packing tape" as Dick discussed is used through 1970 Corvettes. I don't recall seeing it on any 1971s, and surely not those built in the latter half of the production year. So, if you have a 71 or later, don't wrap with this.
        There is a second type of tape used to hold the vacuum lines together along the left (driver's) inner fender as well as other locations. It is black, and similar to the cloth electrical tape used in years gone by. I've used this type of tape on my cars with good success. Well, at least none of the judges noted it.
        Patrick
          • 11644
          Patrick
          • Zachary K.
            • March 1, 1986
            • 162
            If I remember correctly you can buy the 3M packing tape in a thinner width but you still have to slice it down or in half to get the correct size. Also from what I recall the original tape have almost double the amount of threads running through the tape, but having the correct tape is what they are looking for not the number of threads. Also on the headlight actuator and wiper door actuator under the dash is a black tape which I haven't been able to find anywhere, it has a celophane or glossy look to it but the sides show a type of cloth as the previous poster has listed. At the present time I do have the dash out and can take a picture of that tape along with the way it is wrapped. All I have to do is figure out how to post it here. Or you can email me and I will send the pictures that way.
            1967 L79 Sunfire Yellow Black Leather Convertible- Duntov
            1969 L71 LeMans Blue, Bright Blue Convertible
            1970 L46 Monza Red, Light Saddle Convertible - Duntov
            1976 L82 Classic White, Firethorn
            2013 LS7 Black, Ebony, Convertible
            Moved on -
            2006 LS2 Black, Ebony, Convertible
            • Zachary K.
              • March 1, 1986
              • 162
              Moved on -
                • 11644
                heater hoses
                How about Doc Rebuild part number 8845242? If the JG now suggests that you not have GM lettering on them, then I'd suggest using lacquer thinner to remove the GM logos just like the rest of us do.
                Patrick
