70 HL washer anti siphon barrel? - NCRS Discussion Boards
    Re: 70 HL washer anti siphon barrel?
    The valve used on the Camaro was P/N 4919503, which was installed by the assembly plant (they made up the hose assembly); the P/N on the valve used on the Corvette may not show up in the A.I.M. if the valve was included as part of a supplier-built hose assembly.
      Dennis -
      No, it's not - the repro systems for the Camaro restorers use a disc-shaped metal check valve instead with two nipples on one side and one on the other; the solenoid valve for the washer pump for the Camaro system isn't reproduced either.
        Dennis -
