67 Gauge Cluster "LC" - NCRS Discussion Boards
  • Bob H.
    • July 31, 2000
    • 810
    I have a 67 that I believe started life as a 427-400 HP.
    There is a label on the rear of the cluster with a large "LC" on it. I'm having a hard time seeing the small numbers but does this marking mean anything?
    Thanks.
    Re: 67 Gauge Cluster "LC"
    Yes -- the decal specifies the combination of tachometer and oil pressure and temperature and speedo that was installed in the cluster. This one is off my '65, and it means 6500 rpm redline with 80 lb oil gauge. Others will respond with the exact answer to your "LC", but I suspect it is the 6200 rpm redline with 80 lb ??? oil for '67. I see Long Island is repopping these, but their catalog does not say what instrument combinations they represent.
    • Bob H.
      • July 31, 2000
      • 810
      Yes Wayne.
      Tach number I think ends in 222
        Originally posted by Bob Hoffman (34576)
        ....Tach number I think ends in 222
        That's it; Gr 9.750 # 6412522 is the tach with a redline that starts at 6000 rpm. The 6500 rpm redline is 6412223 and the 5300 redline is 6412222.
        • Stephen L.
          • May 31, 1984
          • 3158
          Bob,
          The cluster sticker lettering for 67:
          Sticker background color = white
          Color Letters Tach Oil HP OPTION ASSY #
          RED LA 5300 60 300 #6457982
          RED LC 6000 60 350 #6457985
          RED LC 6000 60 390 #6457985
          RED LC 6000 60 400 #6457985
          RED LB 6500 80 430 #6455364
          RED LB 6500 80 435 #6455364
          GREEN LG 5500 60 300 SPEED WARNING #6458840
          GREEN ?? 6000 60 350 SPEED WARNING #6459496
          GREEN ?? 6000 60 390 SPEED WARNING #6459496
          GREEN ?? 6000 60 400 SPEED WARNING #6459496
          GREEN ?? 6500 80 430 SPEED WARNING #6459495
          GREEN ?? 6500 80 435 SPEED WARNING #6459495
          • Patrick T.
            • September 30, 1999
            • 1286
            Here is the LC sticker on the back of my '67 327/350 cluster assy. PT
            • Kirk M.
              • June 30, 2006
              • 1036
              White sticker for a 67 327/300 automatic with red "LA". Dash has 5300 tach and 60 lb oil pressure
              LA CLUSTER 6457982
              SPEEDO 6455367-W
              TACH. 6412222-W
              AC--MADE IN U.S.A.
              • Nick L.
                • May 31, 1998
                • 82
                Hmmm...was curious about mine and just walked out to the garage to check. Car is a 390 without speed warning, per the original tank sticker I removed from the car. Mine shows "LB" and P/N 6455364. Oil gauge is correct 60# for a 390 and the tach is a NOS replacement with 6K redline. PO told me he had sent the cluster out for restoration a few years ago, and it does look perfect. I wonder if that "restoration" was actually an exchange.....
                • Stephen L.
                  • May 31, 1984
                  • 3158
                  At this point about all you can do is swap the sticker.The resto shop probably mixed up the housings. Assume the gauge needles all match? There are small differences in the needles and script ; original to repop.
                  • Nick L.
                    • May 31, 1998
                    • 82
                    Stephen,
                    This car is a daily driver so I don't sweat details like this; the needles are all ostensibly the same but I do not know the differences in the script to determine whether any of the gauges could be reproductions. Further confusing is the fact that all the lenses are installed the wrong way. They are convex as would be on a cluster with the speed-minder feature.
                    • Stephen L.
                      • May 31, 1984
                      • 3158
                      A good winter project. Remove the cluster and reverse the lenses to the correct orientation.
                      • Chris E.
                        • November 3, 2006
                        • 1326
                        Here's my original, 327/350 no speed warning.
                        Chris Enstrom
                        2011 Z06, red/red
                        • Robert C.
                          • December 1, 2005
                          • 164
                          Steve,
                          I don't suppose you ever run across cluster tags for 1978 to 1982 Corvettes?
                          trying to decode one.......
                          • Stephen L.
                            • May 31, 1984
                            • 3158
                            I'm a '67 guy... have no idea about the later models. Sorry.
                            • Robert C.
                              • December 1, 2005
                              • 164
                              I "took a shot" 'ya might know.
                              Thanks for the reply
