I am doing an off body restore. I have a s/b 300hp. Build date is co4 engine date is 9/27. The tim book indicates that a #8338 with a cast nose would be correct. I also notice that based on my early car build date if the #8361 would work if it had a cast nose. Trying to keep the car close to original for possible judging when complete. Jon pirkle mentioned to me that the 8338 is what i need and that the date could have some wiggle room. Very hard to find one exact. Can someone give me a range of dates that would be acceptable to the ncrs.thank your
Correct starter for 1969 base model
Re: Correct starter for 1969 base model
Roger------
The 1108338 is the correct starter. As far as dates go, it's the same as for any other dated component. For NCRS judging purposes, you need one that's within 6 month prior to the build date of your car. Typically, the span would be much less but NCRS allows up to 6 months.In Appreciation of John Hinckley- Top
Thanks Joe that gives me some room to find one if John Pirkle does not. Spoke with him in the morning and he said he may have one . Thank youhttps://www.forums.ncrs.org/images/smilies/rolleyes.pngRoger------The 1108338 is the correct starter. As far as dates go, it's the same as for any other dated component. For NCRS judging purposes, you need one that's within 6 month prior to the build date of your car. Typically, the span would be much less but NCRS allows up to 6 months.- Top
