I want to block my heat riser off to the carburetor completely. I'm pretty sure I have read about this before here but I couldn't find the answer to my question. Here goes: Under the Q-jet within the stock aluminum manifold as you know there are two vertical channels which essentially route hot air off the exhaust thru a little channel right under the front of the carburetor. Typically a thin stainless shield is used to cover the entire carburetor base from this heat. It does allow some heat to transfer to the carb though. The carb base gasket goes on over the stainless shield. What I would like to do is plug both the vertical holes under the carb. I believe these holes/channels are completely enclosed in the intake manifold. In other words, if I tap the holes for pipe plugs, will the metal cut by the tap that falls down in there be contained or can it get in to the engine? I would use rolled up masking tape pushed down in the holes which will get most if not all of the debris, but I don't want to take any chances if there is any possibility of the metal getting out of the intake and into the engine.
Sorry for the long dissertation, but I wanted to more thoroughly explain what I hope to do. I am having some issues with hot starts and Cliff Ruggles suggested doing this to help with ethanol fuel boiling problems.
While I'm at it here's one more. Is there a way to block the hot coolant flow under the carburetor other than using intake gaskets not relieved for the coolant passages? If the heater is not desired, could the upper 5/8" nipple coming off the intake manifold and going to the heater core be plugged? Pardon my ignorance but how does the coolant flow to the heater core? Is it from the intake to the core and core to the header tank or the other way around?
Thanks a second time!
Thanks for your thoughts,
Brad
Brad
