PV tips - NCRS Discussion Boards
PV tips
  • Michael J.
    • January 27, 2009
    • 7175
    PV tips
    My C2 has been accepted for its' first PV (and mine) at the Nationals next month. Obviously I have been prepping and stressing over it, practicing, etc. I have been collecting tips from ones who have done it and am wondering about a "kit" I should have with me for possible quick repairs. I have an extra set of headlights, fuses, worm gear clamps, tools (screw drivers, wrenches, etc.) flasher, bulbs for various lights. Anyone have any other tips? Thanks.
  • Mike M.
    • May 31, 1974
    • 8409
    Re: PV tips
    antacids. good luck,mike
    • Bob D.
      NCRS Shipping Data Report Manager
      • April 30, 1996
      • 799
      Re: PV tips
      I would bring extra bulbs for the parking lights, interior lights, etc. Also get to Kansas City early so you can run through the PV yourself before the actual test. You never know what might shake, rattle or roll loose while getting the car there. Best of luck with your PV and as Mike said take some antacids along! Bob
      • Ara G.
        • January 31, 2008
        • 1108
        Re: PV tips
        Mike, first of all good luck! Enjoy it. I know it's stressful. Bring beer, extra cigarette lighter element, fuses, duct tape, reverse light bulbs (bringing a 67?) white lithium grease, large blanket to put on ground in case you gotta end up there to fix something, fluids for the car, syringe to prime the washer pump, and I am sure others will chime in. Good luck and keep us posted! ARA
        • Jim S.
          • March 13, 2013
          • 360
          Re: PV tips
          Kansas City has an elevation between 750 and 1100 feet above sea level. The difference from the 'High Mountains of New Mexico' may require a little adjustment with your carburetor ;-)
          • Michael J.
            • January 27, 2009
            • 7175
            Re: PV tips
            I have purposely kept the carb as it was set up for North Carolina/Florida in its' previous life, never re-jetted it for my 7000' elevation. It should be OK, I hope.
            • Chuck M.
              • February 1, 2002
              • 335
              Re: PV tips
              Mike,
              As everyone has said best of luck. I would be happy to share our experience with you and the preparation we took when we passed ours at last years convention. Feel free to send me a PM or email and I'll gladly give you a ring to discuss.
              Good Luck!
              Chuck
              • Arland D.
                Moderator
                • July 31, 1980
                • 430
                Re: PV tips
                Drive it daily and when you get to KC try to enjoy the experience of showing what your car can do.
                • Michael J.
                  • January 27, 2009
                  • 7175
                  • Mike M.
                    • May 31, 1974
                    • 8409
                    Re: PV tips
                    duct tape is to secure team leaders pie hole. mike
                    • William C.
                      • May 31, 1975
                      • 6037
                      Re: PV tips
                      DRIVE the car around home testing all the PV functions with a Critical eye. How much play in the window cranks for the vent windows. Odo and trip ODO correct? Speedo noise? Shifter rattle? Gear noise either accel or Decel. Recheck all the lamps including the "Blinker" bulbs in the dash. Then calm down and enjoy yourself.
                      Bill Clupper #618
                      • Michael J.
                        • January 27, 2009
                        • 7175
                        Re: PV tips
                        • Gary J.
                          • April 1, 1980
                          • 1246
                          Re: PV tips
                          Check vent window for slop, no movement in door hinges, heater and vent control cables for smooth operations. Don't leave any stones unturned. You still have a few weeks, it would be nice if your chapter could do a shake down. Good Luck!
                          • Michael J.
                            • January 27, 2009
                            • 7175
                            • Jaime G.
                              • April 1, 1988
                              • 480
                              Re: PV tips
                              Michael,
                              I have done this test 6 times and have passed 4 times. What has been suggested above is all fine.
                              Main thing to do is to do the Entire test as many times as possible at home..Make sure you have
                              correct tire pressure in spare. Make sure wiper squirters function properly. Make sure keys function
                              as designed. Most of all, relax..It is a great experience..Best of Luck!
