Re: Do I need to double clutch?
Well, I'd try it in my 67 but it doesn't have pedals right now.
What Duke said (along with the other good points) about learning double clutching first is the easiest way to do it.
IF you have another car to practice with, what I teach my students is to practice using the upper gears, 6-5 or 5-4. These are the much easier to work with. Guys who go into a parking lot trying to use the lower gears just get frustrated. You can work on downshifting on a highway/interstate (with no other vehicles close to you) easily.
You'll know you are getting it when the car neither speeds up or slows down as soon as you let the clutch out (revs matched correctly).
These downshifts can be as smooth as silk.
Having the brake pedal forward of the gas pedal does make it a tad harder but it still can be done. I'd suggest that you practice some in the 67 without the engine running.
Have fun.
Have fun.
