1995 Mufflers - NCRS Discussion Boards
1995 Mufflers
  • Mark C.
    • March 1, 1993
    • 26
    1995 Mufflers
    I searched the archives and was unable to find what I'm looking for. The NCRS Tech Info and Judging guide did not help either. I have 2 mufflers that came off of a '95 pace car (I used to own it). The numbers are as follows. GM 10255648 followed by G13 2390 WLN on left muffler, G13 2390 WRN on right muffler, followed by 4 1 072 5A and 4 1 083 5A. I can find no reference to these numbers. I think the last numbers are julian dates 72nd and 83rd days of '95 (which would coincide with the approximate build date of the car - vin 5112934) but I'm not sure. These may just be replacement mufflers. Any help appreciated.
  • William C.
    • May 31, 1975
    • 6037
    Re: 1995 Mufflers
    First question, OEM mufflers were a welded construction to the pipe heading foreward under the body. Svc Replacement were generally clamped foreword of the muffler inlet. Which design are yours?
    Bill Clupper #618
    • Ken R.
      • August 31, 1980
      • 308
      Re: 1995 Mufflers
      Here is a scan of my notes I made on my new 95; built Dec, 94. My writing not too good even then. Date code: outward embossed letters 3/8" high. Right muffler 10255648 YBR; G13-2390-WRN; 4 1 326-4A. Left muffler same as right except WLN instead of WRN. VIN 9625.
      • Mark C.
        • March 1, 1993
        • 26
        Re: 1995 Mufflers
        These were welded.
        • Mark C.
          • March 1, 1993
          • 26
          Re: 1995 Mufflers
          So it appears these mufflers are original to the car. Were they only on the pace cars? Wondering why no mention of these part numbers in the NCRS manuals.
          • Mark C.
            • March 1, 1993
            • 26
            Re: 1995 Mufflers
            Does anybody know why this information is not in the NCRS manuals?
            • Pat F.
              • April 1, 1981
              • 856
              Re: 1995 Mufflers
              Mark, attached is a photo of the original right side muffler off of my 1995. I do not have a Pace Car. Most of the numbers match the ones you set out.
              The Julian Date code is 203 4. This represent July 22, 1994. My 1995 has a build date of August 4 , 1994. This was either the first or second day of 1995 model production.
              On page 223 of the 1994-96 Judging Manual, under the Muffler section, it calls for a part number of 10143518. As you can see the number on the two mufflers we are discussing is 10255648. I am presuming, bad thinking, that each year and probably hp have different muffler identifiers. This issue hs been discussed with the National Judging Chairman for the 1990-96 Judging Class.
              The Chevrolet Parts Manual shows 10255648 as a muffler part number for the 1995 LT1.
              Hope this helps.
              PAT, Central New Jersey and Florida Chapters
              • Mark C.
                • March 1, 1993
                • 26
                Re: 1995 Mufflers
                Lots of discrepancies they need to clarify. I've found other mufflers with different numbers too.
