Motive brake bleeder - NCRS Discussion Boards
  • Robert B.
    • May 31, 2005
    • 163
    Re: motiv brake bleeder
    I just finished bleeding my '66 power brake system. I had replaced the calipers, rebuilt the MC, and flushed out the brake lines so everything was clean. After one operator screw up - I had rolled over the primary seal on the primary piston, and hadn't realized it, so I had to pull the MC off again and replace the seal, the whole bleeding process only took about 20 minutes. What a great system!! I found that starting with each reservoir about half full, after I had bled the brakes, released the pressure and removed the pressure adapter, the reservoir was still just over half full. Didn't spill a drop.
    I had been trying to get them bled with a vacuum bleeder to no avail - the only thing those vacuum units are good for is removing old fluid from the MC!
    Bob
    • Michael B.
      • April 1, 1999
      • 178
      I did the same as David Olson today and when I first bled the system new, just unscrewed the Motiv to relieve pressure and it pulled fluid back into the tank with no leaks.
      Cheers.
      Michael B.
      • Brian M.
        • February 1, 1997
        • 1842
        #18
        I prefer the Vacula system which sucks fluid thru the system with shop air.
        • Edward B.
          • January 1, 1988
          • 537
          #19
          This discussion makes the time-tested two-person method look pretty good.
          • Mike T.
            • January 1, 1992
            • 570
            #20
            Ed - I agree, the two-person method was the simplest approach but as the years passed by and there were fewer and fewer local 'wrenchers' around to help out when needed, that's the reason I moved on to the Motive Bleeder.
            Mike T. - Prescott AZ.
            • Michael F.
              • 745
              #21
              I use the gravity system and just do other things in the garage and keep an eye of the fluid level, to cheap to go high tech I guess.
              Michael
              70 Mulsanne Blue LT-1
              03 Electron Blue Z06
