Steel Wheel Balancing Question: - NCRS Discussion Boards
  • Ralph B.
    • July 30, 2008
    • 178
    On a 66 steel wheel does it matter if the rim is "hub centered" or "lug centered" for the balancing process on a GSP9700 machine?
    Thank you,
    Ralph
    Re: Steel Wheel Balancing Question:
    Thank you,
    Ralph
    Ralph -
    Corvette steel wheels are lug-centric - tell the technician if his book doesn't show that.
      • 15616
      Ralph -
      C3s too, John?
        • 43248
        C3s too, John?
        Terry------
        Well, let's put it this way: the rear spindle hub OD dimension for 1965-82 Corvettes is 2.778". The wheel center hole dimension for all 1965-82 Corvette wheels except 63-67 aluminum is 2.783". So, with this relationship, the hub is going to center the wheels whether or not the lugs do.
          • 15616
          Terry------
          So with 0.005 clearance on the hub why are they not hub-centric?
            • 43248
            Terry------
            That I do not know.
