1956 Distributor - NCRS Discussion Boards
1956 Distributor
  • Dan A.
    • May 31, 1974
    • 1073
    1956 Distributor
    What is the earliest known date on a 1110879 distributor and the VIN of that car?
    What is the latest known 1110872 date and VIN on that car.
    FWIW I am familiar with what the latest manual says.
    Dan
  • Edward M.
    • November 1, 1985
    • 1922
    Re: 1956 Distributor
    I have an 872 out of VIN 2117 (estimated build date 4/24/56) that is dated 6 C 5. That is all of the actual data I can supply.
    • Dan A.
      • May 31, 1974
      • 1073
      1110872-6C5 (Small).jpgThanks Ed. Your 872 distributor from VIN 2117 probably looks just like the picture I have attached.
      For clarification, when you say VIN 2117 I am assuming that is E56S002117 or the 1117th car built.
      • Edward M.
        • November 1, 1985
        • 1922
        Originally posted by Daniel Adie (60)
        [ATTACH=CONFIG]53127[/ATTACH]Thanks Ed. Your 872 distributor from VIN 2117 probably looks just like the picture I have attached.
        Correct. My (and I assume many others) short hand for the VIN is the last four (or 5 or 6 as the case may be) digits of the actual VIN. E56S002117.
        • Dan A.
          • May 31, 1974
          • 1073
          I asked because '56 VINs started at 1001 and that can sometimes cause a little confusion date wise if 1000 aren't subtacted from the VIN sequence number to put the actual sequence number in perspective.
