Probably easy ones... I'm about to fix the headlights for my 65. Buckets are rotating, but the light doesn't work 100% at the moment.
What is (or should be) correct when you turn on the headlights? All four light up, only the outer ones, or? And for the high beam? I've seen different versions...
Many thanks!
Roger
Many thanks!
Roger
