Let there be light: 1965 headlight questions - NCRS Discussion Boards
  • Roger L.
    • August 24, 2012
    • 1
    Probably easy ones... I'm about to fix the headlights for my 65. Buckets are rotating, but the light doesn't work 100% at the moment.
    What is (or should be) correct when you turn on the headlights? All four light up, only the outer ones, or? And for the high beam? I've seen different versions...
    Many thanks!
    Roger
  • Mike T.
    • January 1, 1992
    • 569
    Re: Let there be light: 1965 headlight questions
    Roger - Depends on whether you have the high beams activated with the foot switch or not. If none of the headlights (low or high beam) are lighting up, could be the dash pull switch and maybe the foot operated dimmer switch, if I'm understanding your question correctly. Any recent work done up front that might have disturbed the wiring?
    Mike T. - Prescott AZ.
    • Wayne M.
      • March 1, 1980
      • 6414
      Originally posted by Roger Lingmert (55323)
      .... What is (or should be) correct when you turn on the headlights? All four light up, only the outer ones, or? And for the high beam? I've seen different versions...
      Depends on whether you last had the (floor) headlight selection switch on high or low beam. ..... Different versions ? Are you talking about the (again) floor switch ?
      Here's 2 styles I'm aware of .. believe the one on the right is correct for C2's.
      P.S. Michael T. -- you beat me to it by one minute .
