Identify This Thermostat Housing. BB? - NCRS Discussion Boards
  • Raymond G.
    • March 1, 1980
    • 31
    I have a cast iron housing and the only recognizable numbers are 6065 on the underside of the neck. What app is it?
    Raymond
  • Domenic T.
    • January 29, 2010
    • 2452
    Re: Identify This Thermostat Housing. BB?
    Ray, I think all the BB housings were aluminum. Maybe wrong but I did some research on some BB housings and they were all aluminum. The experts here will tell you.
    DOM
    • Raymond G.
      • March 1, 1980
      • 31
      Thanx Dom, you're probably right although this came off a big block to the best of my knowledge but I still would like to know what it's for.
      • Domenic T.
        • January 29, 2010
        • 2452
        Ray,
        I was thinking C2 BB. It would help to know the year. I am not a expert but the SB cast iron housing is easy to spot. I cheat and go on line to licorvette and look at the pictures.
        DOM
          • 43221
          DOM
          DOM------
          Most, but not all, big block thermostat housings were aluminum. Exceptions were 1965 L-78, 1966 L-72 with K-19, and 1967-69 L-88.
            • 43221
            Raymond
            Raymond------
            "6065" is not a GM part number or derivative thereof. However, vaguely, I seem to recall this number on some GM cast iron thermostat housings. If not, then it's an aftermarket housing. In any event, if you could post a picture perhaps we could tell you the application.
