1953 corvette - NCRS Discussion Boards
1953 corvette
  • Joseph K.
    • March 1, 1980
    • 168
    1953 corvette
    Came across a GM cast iron dual exhaust manifold with intake complete. Did all Blue Flames come with dual exhaust? Were these ever installed on corvette? Possible value and desirability. Thanks in advance!
  • Chris S.
    • January 1, 2000
    • 1068
    Re: 1953 corvette
    Joe
    the dual exhaust manifold was Corvette only for 53, 54, 55 235 Blue Flame six
    It was not offered on passenger cars
    the intake is also Corvette only - Cast alum for the three YH side draft carbs
    The exhaust manifold is a little harder to find
    the intake is rather common - are all the "ears" intact? any repairs?
    Does the exhaust riser work?
    Are all the carbs and linkage and fuel line fittings intact?
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • Joseph K.
      • March 1, 1980
      • 168
      Re: 1953 corvette
      Chris
      the exhaust riser is free and in good operating condition, spring is also in good condition. The intake that is bolted on this appears to be an aftermarket set-up for a two-barrel obviously incorrect per your description. What would be the value of such a exhaust manifold, GM made?
      • Greg P.
        1961-62 Team Leader
        • March 1, 1985
        • 55
        Re: 1953 corvette
        Chris you are right on, and very helpful on this board. Thanks
        • Gary C.
          Administrator
          • October 1, 1982
          • 17928
          Re: 1953 corvette
          Joe, please post the part number cast into the exhaust and any other numbers. Gary....
          It wasn't uncommon to modify a standard 6 cylinder single exhaust into a dual exhaust back in the day.
          NCRS Texas Chapter
          https://www.ncrstexas.org/
          • Joseph K.
            • March 1, 1980
            • 168
            Re: 1953 corvette
            Gm 1-3836108
            • Chris S.
              • January 1, 2000
              • 1068
              Re: 1953 corvette
              A good exhaust manifold with a free riser in good condition sells for around 600.00
              can you post a photo?
              • Joseph K.
                • March 1, 1980
                • 168
                Re: 1953 corvette
                Not able to post picture at this time but soon. I will be attending the national meet in KC as I live a short distance away. If someone would like to see this in person that would be a great opportunity, I'm going to the swap meet as well.
                • Tom P.
                  • April 1, 1980
                  • 1826
                  Re: 1953 corvette
                  I don't know where you grew up, but around here all us guys with 6cyl Chevys promplty went to a local muffler shop to get duals installed on our 6cyl Chevys. This included removal of the intake/ex manifolds, a slot cut in the ex manifold so that a plate could be installed and welded in place which made a FULL BLOCK between the front/rear 3 cylinders and then a hole cut in the rear part of the ex manifold and another flange welded in place. MOST of us had Smithys (the H is silent) glasspack mufflers installed and we then had hot Chevys!
                  The "rich" kids went to the local Chevy parts dept and bought a 6cyl Vette ex manifold for $17. I acquired mine (and still have it) from a salvage yard for about $5. I mated it to an aftermarket alum intake with 2 carbs. Ran that setup on a 261 in my 51 Chevy until I installed the first V8 (283 with 2x4s) in 67.
                  • Chris S.
                    • January 1, 2000
                    • 1068
                    Re: 1953 corvette
                    I will be there with our 54 - look forward to meeting you - Chris
                    • Chris S.
                      • January 1, 2000
                      • 1068
                      Re: 1953 corvette
                      Thank you Greg - I try to help !! - Paying it forward as many have helped me......
                      • Joseph K.
                        • March 1, 1980
                        • 168
                        Re: 1953 corvette
                        Where would the casting date be on the exhaust manifold? Will post a picture this evening if I am able.
                        • Chris S.
                          • January 1, 2000
                          • 1068
                          Re: 1953 corvette
                          Its towards the back of the manifold......
