1966 1967 frame question ??? - NCRS Discussion Boards
  • Paul S.
    • June 30, 1982
    • 359
    Correct me if i am wrong . Only difference in a 66 and 67 frame? The emegency brake cable " wheel" bracket ?
  • Barry H.
    • April 30, 1976
    • 213
    Re: 1966 1967 frame question ???
    Paul, The 67 shifter was bolted to the crossmember instead of being bolted to the transmission tailshaft, I believe it was to stop the annoying shifter vibrations. This particular upgrade actually started in late 66, I have a july 66 s/n 25,66x & this car has the crossmember mounted shifter. Barry Holmes
    • Paul S.
      • June 30, 1982
      • 359
      Forgot about the shifter , thanks. I have a friend who has a 67 that needs a frame , we found a 66 frame ( close to us ) that is suppose to be real nice . We want "convert it" to a 67 , if there isn't that many things to change.
      • Timothy B.
        • April 30, 1983
        • 5203
        Paul,
        Keep in mind cars are separated from the frame for reasons, you better cross check the frame or have someone look at it for you.
        • Jerry M.
          • March 1, 1978
          • 147
          Paul
          Another small difference that comes to mind is a '66 frame has one clip for the front crossover brake line, centered on the front of the front crossmember, while a '67 has two clips around 1/3 and 2/3 across the crossmember (distances might be off some, it's been awhile and the memory's going). This should be an easy fix though.
          Jerry
          • Keith B.
            • March 7, 2008
            • 928
            Originally posted by Timothy Barbieri (6542)
            Paul,
            not anymore with the craze of resto mods
            • Paul S.
              • June 30, 1982
              • 359
              Thanks for the help. (the frame the 66 is coming out of, to sell, is going to have a pro touring frame installed in it)
              • Bill M.
                • 1330
                Make sure the numbers on the frame match the vin on the car that t is coming out from under . don't want any surprises down the road
