Torque Bolt Question - NCRS Discussion Boards
  • Larry S.
    • September 19, 2007
    • 204
    I am replacing the exhaust system on my 66 427-450 car and am wondering what torque spec to use for the 3 manifold to exhaust pipe bolts ( 3 on either side of engine)?I cant seem to find it in any of my current information.
  • Pete L.
    Infrequent User
    • July 31, 2001
    • 12
    Re: Torque Bolt Question
    Larry,
    Torque should be 13-17 Lbs-ft
    • Carl N.
      • April 30, 1984
      • 592
      I always go back and re-torque after several starts then again in about 6 months - the heat can effect these fastners
      • Michael G.
        • November 12, 2008
        • 2157
        Well, not really the fasteners, but certainly the parts they're attaching...
        Mike
          • 43218
          Michael------
          Yes, the heat and compression definitely affects the exhaust packings. However, there's a way around this-----use sintered iron rings instead of the packings. These are all I use. They're essentially "immortal" and pretty much eliminate the need for repeated re-torquing of the flange nuts.
          2" = GM #3731062
          2-1/2"= GM #3768711
          Are the above original for Corvette? Only if you have a 1975-81. But, they work very well for all earlier.
          • Gary B.
            • February 1, 1997
            • 7018
            Michael------
            2" = GM #3731062
            2-1/2"= GM #3768711
            Does anyone know if Fel-Pro# 60985 is sintered and is that item the 2" size?
            Gary
              • 43218
              Gary
              Gary-----
              I believe it is sintered iron but I'm not 100% sure. It is for 2" exhaust.
              • Larry S.
                • 204
                Thanks for all that good information. It really helps.
