I am replacing the exhaust system on my 66 427-450 car and am wondering what torque spec to use for the 3 manifold to exhaust pipe bolts ( 3 on either side of engine)?I cant seem to find it in any of my current information.
Torque Bolt Question
Re: Torque Bolt Question
Well, not really the fasteners, but certainly the parts they're attaching...Mike
1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.- Top
Michael------
Yes, the heat and compression definitely affects the exhaust packings. However, there's a way around this-----use sintered iron rings instead of the packings. These are all I use. They're essentially "immortal" and pretty much eliminate the need for repeated re-torquing of the flange nuts.
2" = GM #3731062
2-1/2"= GM #3768711
Are the above original for Corvette? Only if you have a 1975-81. But, they work very well for all earlier.In Appreciation of John Hinckley- Top
Does anyone know if Fel-Pro# 60985 is sintered and is that item the 2" size?Michael------
2" = GM #3731062
2-1/2"= GM #3768711
Gary- Top
- Top
