pics of a harmonic balancer for 1959 245 hp - NCRS Discussion Boards
  • Bob W.
    • December 1, 1977
    • 802
    heading to spring Carlisle and looking for a the right balancer and not sure what to look for. were they also used on pass cars to ?
  • Joe M.
    • April 30, 1990
    • 1338
    Re: pics of a hormonic balancer for 1959 245 hp
    See attached photos
    • Joe M.
      • April 30, 1990
      • 1338
      If you find a balancer that looks like the second photo, but has a ring of holes around the outside diameter, it will work, but it was sold as a service replacement
      • Cecil L.
        • May 31, 1980
        • 449
        Also production on 348 engines.
        • David L.
          • July 31, 1980
          • 3310
          I did some research on the stepped balancers many years ago. I have about a dozen or so of the balancers shown in my drawings (some with the 12 holes around the perimeter and some without). The balancers that I have are from lower H.P. engines. According to my vintage Chev. parts catalogs the 58-58 PASS., CORVETTE w/F.I. and H.L. Cam used balancer # 3742986 which according to Chevrolet Parts History (service parts) was replaced in Nov. 1959 by GM # 3764318 used on 59-61 PASS., CORVETTE w/H.L. Cam, H/Per. (6 1/8" O.D.).
          Dave
          • Bob W.
            • December 1, 1977
            • 802
            thanks for the help guys
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11335
              David.....That's great information and data you've posted. Thanks for sharing that!!!
              Bob, If you find one and the rivets are loose, there's a rebuild kit availavle with new rubber insulator and rivets. However you need a hydraulic press and the ability to get a air hammer in there to peen the rivets. But just make sure the inner surface of the snout isn't worn too much. It's a press fit to the crank.
              I had one with the outer holes on a mongrel '57 '548 Flint 283 in a buddy's 59 a few years ago that had loose rivets, but the rubber was okay. It actually was rattling. I compressed the balancer in my 20 ton press and took a air hammer with chisel tool to the rivets. Didn't come out exactly pretty but it tightened it up nicely and the pulley covered up the mis-hits. My buddy didn't want to spring a few hundred $'s for a replacement.
              Someone in the past put a repair sleeve on the snout, but over the years it got beat on pretty badly. The crank was a mess too. I drilled and tapped the crank for the 7/16"-20 HB bolt to keep it safely installed. Not original for a '59 but it added a margin of confidence so it wouldn't come off. I lost one on my own '59 270hp years ago while driving on the highway, and watched wide-eyed as I saw it in the rearview spinning along and then passing me on the left and ended up in the median. Put a new GM OTC replacement on it.
