tach cable broke 67 - NCRS Discussion Boards
tach cable broke 67
  • Al R.
    • June 30, 1988
    • 688
    tach cable broke 67
    New tach cable, distributor rebuilt by J Fiedler, and tach restored by Joe Ray. Tach cable broke into about 4-5 " from the distributor after only 17-18 miles on the car (total frame-off restoration) during a shakedown run. Where do I need to look for the possible source. I only want to pull the cluster out 1 time. Possible cheap cable crap that's on the market?
  • Harry S.
    • July 31, 2002
    • 5333
    Re: tach cable broke 67
    Al, I assume the inner cable broke. This has nothing to do with a frame off or a tachometer restoration. I had the same problem with my 63. While driving to a Regional to be judged my inner cable broke. Why, I have no idea why.
    Anyway, I believe Autozone has an inner cable kit. Part 03368 for $9.99. Do not pull the cluster, reach under and disconnect the tach cable, disconnect at the distributor, pull it out. Measure the old broken part then cut and make a new inner from the kit. Clean the inside of the outer cable, lube the inner and outer and reinstall. You should be good to go.
    • Don L.
      • August 31, 2005
      • 1005
      Make sure the routing of your cable has as gradual and wide radius turns as possible, especially as it approaches the distributor. A tight bend can cause the cable to break. Don't ask me how I know...
      Don Lowe
      NCRS #44382
      Carolinas Chapter
      • Al R.
        • June 30, 1988
        • 688
        Harry, thanks for the info. Didn't realize Autozone carried the cable. Yeah it is the inner. Disconnect from the tach is easier said than done as you are aware, plus I have an A/C duct to also remove (which shouldn't be a problem. What's the best method of cutting the new cable? Thanks, Al
        • Al R.
          • June 30, 1988
          • 688
          Don, the bend didn't look to be too sharp, but could maybe be wider. Any way to keep the bend wide w/o it narrowing by itself by it's own tension?
          • Harry S.
            • July 31, 2002
            • 5333
            I also have A/C. You need to remove the duct and the hose. You can get the cable disconnected at the tach unless a prior owner wrenched it down. Hand tight is all you need. The kit is self explanatory at what end to cut. Just make your cuts really accurate.
            • Gerard F.
              • June 30, 2004
              • 3806
              Al,
              Just a thought, I think we have the same engine, 67/327/300 isn't it?
              If so, maybe the distributor restorer reversed the dimple on the distributor shaft to the rotor position.
              If so this would give you an excessive bend in the tach cable.I had a replacement distributor on my car with a dimple reversed to the rotor, and always had problems with the tach cable. When I put my original distributor back on with the dimple aligned to the rotor, there is less bend in the cable, and the problems went away.
              Please see the first post in the attached thread:
              https://www.forums.ncrs.org/showthre...DistributorThe
              The first picture in the first thread is the correct position of the distributor (with dimple and rotor aligned) at 6*BTDC. The second picture is with the dimple reversed.As you'll see, there is less bend in the tach cable with the dimple aligned.
              Just a thought, I might be all wet for your problem.
              Jerry Fuccillo
              • Al R.
                • June 30, 1988
                • 688
                Jerry, I went thru that early on and had to reverse the gear in order to time the engine due to the cam manufacturing not being degreed correctly as compared with the original. Thanks for the input though! Al
                • Al R.
                  • June 30, 1988
                  • 688
                  Harry, this is no longer available from Autozone. Checked on it today. Any other source you may know off? Thanks, Al
                  • Harry S.
                    • July 31, 2002
                    • 5333
                    I bought one last week????? I'll go to the local shop and if they have a few I'll get them and send you one.
                    • Al R.
                      • June 30, 1988
                      • 688
                      Thanks Harry! let me know. It will be the weekend before I'll get a chance to get back on it anyway. Got to head back to Tn in the morning to work, and will be Fri getting back. Al
                      • Jack H.
                        • April 1, 2000
                        • 477
                        If Harry doesn't come up with one, here are some alternatives:
                        Free Shipping - Dorman Speedometer Cables with qualifying orders of $109. Shop Speedometer Cables at Summit Racing.
                        http://www.amazon.com/Dorman-03368-T.../dp/B000CO8ZPQ
                        • Harry S.
                          • July 31, 2002
                          • 5333
                          The kits that Jack pointed to are exactly the same, it would be easier to check them out first if there in your area. Also the prices are lower. Just remember that a small washer is needed so use the one that is there now don't discard it.
                          • Al R.
                            • June 30, 1988
                            • 688
                            Thanks Harry and Jack, I will call them tonight. Al
