68 Rear Crossmember rubber removal - NCRS Discussion Boards
  • Jeff P.
    • 799
    I couldn't find any info in our searches . Crossmember came off great. Not too much trouble. Is there a technique in removing the rubber? Is there a certain tool that will lift up the tabs without hacking them up? Thanks, Jeff
    68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
    2014 Arctic White Z51 Vert. (Wifes)
  • Michael W.
    • April 1, 1997
    • 4290
    Re: 68 Rear Crossmember rubber removal
    You will need to press them out which will destroy them in the process. I've never yet seen one of these bushings that was damaged in any way other than cosmetic surface checking.
    I'd leave well enough alone.
    • Jeff P.
      • 799
      Thanks for the response Mike. Not what I wanted to hear. I'm acid dipping all the rusted sub frame pieces. Everything else is being done over so why stop here. But you never know, I might take your advise.
        Jeff -
        You might want to review this article I wrote on removing/replacing those "sombrero" bushings:
        http://www.lbfun.com/warehouse/tech_...breroDance.pdf
        • Jeff P.
          • 799
          Thank you John. Great reading. I also want to thank you for a great presentation at the New England Chapter Lecture Series. Classic .
