1954 Intake/exhaust bolt torque specs - NCRS Discussion Boards
  • David W.
    • May 31, 1990
    • 51
    Is 25-35 ft/lbs correct for attaching the intake manifold on a 1954 6 cyl. engine?
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11366
    Re: 1954 Intake/exhaust bolt torque specs
    David, According to the 1955 Chevrolet Passenger Car Shop Manual..........
    Manifold center clamp bolts ......15-20
    Manifold end clamp bolts...........25-30
    I found it here.....under "Valve Adjustment"
    • Troy P.
      • February 1, 1989
      • 1284
      Just be careful as the Corvette manifold is aluminum and not as hardy as the cast iron passenger manifolds. I've seen quite a few aluminum ones with the "ears" broken off.
      • David W.
        • May 31, 1990
        • 51
        Amen to that! I had one of the "ears" crack. It repaired perfectly, however.
        Dave
