1968 nos cam 3863151 - NCRS Discussion Boards
  • Jeff P.
    • 797
    I have a chance to purchase a L79 NOS cam 3863151. Is this the original piece for a correct L79 ? I looked back and the mid years used a different number. Thanks in advance. Jeff
    68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
    2014 Arctic White Z51 Vert. (Wifes)
  • Paul O.
    • August 31, 1990
    • 1716
    Re: 1968 nos cam 3863151
    Jeff
    Just type in the part # 3863151 in the search box top right corner you will get 2 pages of earlier discussions.
    • Jeff P.
      • 797
      Thank you Paul. Do you have an email address that I could send 68 questions to or is this fine. I'm the one that brought some door glass over to you at Carlisle. Thanks, Jeff
      • Paul O.
        • August 31, 1990
        • 1716
        Jeff
        oslansky@fuse.net
        • Jeff P.
          • 797
          Thank you Paul
            • 43201
            Jeff-------
            GM #3863151 is the correct cam for ALL L-79, 1968 and otherwise.
            • Jeff P.
              • October 21, 2011
              • 287
              Jeff,
              If you can get 2 cams i'll take one. Are these still available with lifters and springs.
              • Jeff P.
                • 797
                Jeff, I'll send him an email. Not sure on any availability of lifters and springs.
                  • 15636
                  It doesn't make sense to buy a "NOS" camshaft when you can buy the exact same thing, built to the GM print, manufactured by Federal Mogul and/or Dana Corp, unless the NOS cam is the same price, but typically the asking price is as if an exact duplicate is not available from any other source.
                  OE type hydraulic lifters are also available from the same sources as are exact OE replacement valve springs, Sealed Power VS677, which are about a buck apiece.
                  All of the above can be purchased from NAPA or any other parts source that carries Sealed Power (Federal Mogul) and Clevite (Dana Corp.) brands.
