Trailer Advice - NCRS Discussion Boards
Trailer Advice
  • Ed N.
    • May 16, 2010
    • 1003
    Trailer Advice
    I'm planning on using my trailer (enclosed 20 footer) to transport my 95 to Kansas with my 1/2 ton 2004 Titan. I've always pulled without issues throughout Florida, but I'm not sure how steep or challenging the highways/roads may be on the way to Kansas. My truck does have air bags and I use a weight distribution system, which helps keep things pretty level and steady. It (the trailer) also has electric brakes and my truck has a brake controller.
    Maybe someone who's traveled those roads can chime in and give me some guidance. I will be traveling from Miami, Florida.
    Would I be OK pulling through that part of the U.S.? I normally don't drive faster than 60 to 65 mph. Here are some pictures of my setup.
    Ed Nieves
    NCRS #51799
  • Dick W.
    • 10483
    Re: Trailer Advice
    If you do not already have it, I would add a sway control arm. Takes some of the worry out of being passed by semis
    Dick Whittington
    • Ed N.
      • May 16, 2010
      • 1003
      Re: Trailer Advice
      Dick, I'll look into it. With my weight distribution bars, I get very little to no swaying when semis come by me. I'm more concerned with how hilly those roads may be and how would my truck respond to them.
      Thanks.
      Ed Nieves
      NCRS #51799
      • Dick W.
        • 10483
        Re: Trailer Advice
        I would look at this route, probably the least amount of hills http://bit.ly/1jsNhCx I know you are in FL so I started the trip from JAX
        Dick Whittington
        • Gary C.
          Administrator
          • October 1, 1982
          • 17771
          Re: Trailer Advice
          Ed,
          Follow Dick's advice and get an anti-sway bar. Reduce your opportunity for problems.
          Dallas to Overland Park, KS using I35 to Kansas Turnpike is longer, but a flatter uphill drive.
          Gary
          NCRS Texas Chapter
          https://www.ncrstexas.org/
          • John F.
            • March 23, 2008
            • 2415
            Re: Trailer Advice
            I would probably take a Southern route rather than tackle Mt Eagle thru Tennessee/Georgia.
            • Dave B.
              • August 31, 2001
              • 34
              Re: Trailer Advice
              I have taken this trip numerous times from Orlando towing using various routes. Quickest easiest way is up 75 following route Dick provided. Mt. Eagle is no big deal. Take your time going up and down and you are good to go.
              • Terry D.
                • May 31, 1987
                • 2696
                Re: Trailer Advice
                Better yet drive the car and you won't have to worry about hills! I'm pretty sure the General built them to drive.
                • Dick W.
                  • 10483
                  Re: Trailer Advice
                  I got to thinking, a little quicker route, to me anyway, would be to take I-75 to I-64 W to St Louis, pickup I 70 to KC
                  Dick Whittington
                  • Stephen L.
                    • May 31, 1984
                    • 3162
                    Re: Trailer Advice
                    If you are afraid of the hills and pulling capability, just shift to a lower gear.......
                    • Ed N.
                      • May 16, 2010
                      • 1003
                      Re: Trailer Advice
                      Originally posted by Gary Chesnut (5895)
                      Ed,
                      Gary
                      Thanks Gary, I'm looking at the Curt anti-sway bar system.
                      Ed Nieves
                      NCRS #51799
                      • Ed N.
                        • May 16, 2010
                        • 1003
                        Re: Trailer Advice
                        Got it, thanks...
                        Ed Nieves
                        NCRS #51799
                        • Ed N.
                          • May 16, 2010
                          • 1003
                          Re: Trailer Advice
                          Thanks Dick. Any particular anti sway bar system your prefer? I'm looking at the Curt #17200, since my Wht. Dist. System is from Curt.
                          Ed Nieves
                          NCRS #51799
                          • Ed N.
                            • May 16, 2010
                            • 1003
                            Re: Trailer Advice
                            Thanks Dave. I'll have to Google what Mt. Eagle is because I have no idea.
                            Ed Nieves
                            NCRS #51799
                            • Ed N.
                              • May 16, 2010
                              • 1003
                              Re: Trailer Advice
                              John, what would be the best Southern route?
                              Ed Nieves
                              NCRS #51799
