Is there suppose to be a ground wire from the radio to the passenger side valve cover? Looks like I have one on the driver side is that correct?
Radio Ground Wire see the topless pic 1959 283
Re: Radio Ground Wire see the topless pic 1959 283
I'm guessing that, in this instance, my '62 is the same as your '59. On a '62, the main harness ground goes to the driver's side valve cover. If you bought the radio option, then there was a separate and dedicated ground from the radio to the passenger side inboard valve cover. If you have a radio, then there should be two ground wires to the valve covers - one to the driver and one to the passenger side.- Top
Chris, I think you forgot about the Wiper Ground also on the right side, so 2 grounds on that screw. 1 Main ground on the left. This is for 58 to 62.
Rich- Top
Rich, yes, you're right. I forgot about that one. Thanks for the correction.- Top
