Radio Ground Wire see the topless pic 1959 283 - NCRS Discussion Boards
  • John C.
    • September 30, 2001
    • 130
    Is there suppose to be a ground wire from the radio to the passenger side valve cover? Looks like I have one on the driver side is that correct?
  • Joe M.
    • April 30, 1990
    • 1338
    Re: Radio Ground Wire see the topless pic 1959 283
    Top, rear valve cover screw on passenger side is correct.
    • Christopher R.
      • March 31, 1975
      • 1599
      I'm guessing that, in this instance, my '62 is the same as your '59. On a '62, the main harness ground goes to the driver's side valve cover. If you bought the radio option, then there was a separate and dedicated ground from the radio to the passenger side inboard valve cover. If you have a radio, then there should be two ground wires to the valve covers - one to the driver and one to the passenger side.
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11334
        Chris, I think you forgot about the Wiper Ground also on the right side, so 2 grounds on that screw. 1 Main ground on the left. This is for 58 to 62.
        Rich
        • Christopher R.
          • March 31, 1975
          • 1599
          Rich, yes, you're right. I forgot about that one. Thanks for the correction.
