Re: Cooling System
There shouldn't be any air in the rad once the system is filled and bled unless the head gasket is leaking or he has a cracked block or head. To ensure against the slight chance that air would somehow get into the rad, the cheap, generic "closed system" cap which I suggested Leif install can be modified by several means which will disable the lower seal, but maintain the upper seal and make that cap behave like an ordinary jar lid (seal to atmosphere but keep the 1/4" nipple always open). This isn't the solution that I suggested in an earlier post. The current setup provides operability as an open system, will all the inherent consequences, such as "puking" out the overflow hose with resultant need to monitor coolant level.
Reread my earlier post which recommends how to convert his system to a care-free/trouble-free closed system.
