Cooling System - NCRS Discussion Boards
Cooling System
  • Leif A.
    • August 31, 1997
    • 3654
    Cooling System
    When a '67 L79 with A/C is cool (before start up), what should the coolant level be in both the radiator and overflow tank. I know it sounds silly but I don't want to overfill or underfill before taking out for the first time in awhile. thanks.
    Leif
  • Ralph E.
    • February 1, 2002
    • 905
    Re: Cooling System
    Suggest you follow John Hinckley's method, works every time.
    " the recipe is to fill the engine through the thermostat opening in the intake until the coolant level comes up to the top, then install the thermostat, gasket and housing/upper hose, and continue filling through the expansion tank until the tank shows half-full. Leave the cap off, fire it up and run it until the thermostat opens (upper hose gets hot right away), let it run for five minutes, and shut it down. When it cools, top up the tank to half-full, cap it, and you're done.
    The air in the block has to have a place to vent as it's displaced by coolant when you fill; if there's no place for it to go (or the path is difficult), you wind up with a short-fill and air pockets."
      • 15706
      Re: Cooling System
      Do you have an owner's manual? It should say the expansion (not overflow) tank level should be half full when the engine is cold. The radiator should be full, but there is no access to check it. The coolant quantity is checked as above.
      • Leif A.
        • August 31, 1997
        • 3654
        Re: Cooling System
        gentlemen,thank you very much. Duke, I do have an owner's manual but this forum is so informative with real life experiences that I prefer to ask questions even after reading the manual.thanks, again.
        Leif
        • Leif A.
          • August 31, 1997
          • 3654
          Re: Cooling System
          And, just as a technicality, the owners manual calls the expansion tank a "supply tank". But, I was wrong calling it an overflow tank...only human.
          Leif
            • 43287
            Re: Cooling System
            Leif------
            This is a common misnomer. I've heard the tank called all sorts of things but, correctly, it's a SUPPLY tank. All radiators have supply tanks but most are integral with the radiator. Some, like 63-72 Corvettes with aluminum radiator have no integral tanks and only use an external supply tank. A few have BOTH integral AND external supply tanks (e.g. 1969-72 big blocks with copper/brass radiator).
            If you fill the tank more than half full, that condition will be very short-lived.
            • Leif A.
              • August 31, 1997
              • 3654
              Re: Cooling System
              Thanks, Joe (and, Duke)...half full it is!!
              Leif
              • Thomas N.
                • July 31, 2002
                • 408
                Re: Cooling System
                Or is it half empty?....I've had great results following the filling through the thermostat openings on a flush or new applications also.
                NCRS New England Chapter Chairman 2022, 2024
                N E Regional Chairman 2024
                1967 Corvette Convertible Under Restoration
                1996 Corvette Coupe NCRS Chapter Top Flight 99.5, NCRS National Top Flight 100.0
                • Leif A.
                  • August 31, 1997
                  • 3654
                  Re: Cooling System
                  you say tomato, I say tomoto...who knows???
                  Leif
                  • Timothy B.
                    • April 30, 1983
                    • 5202
                    Re: Cooling System
                    Leif,
                    One thing to remember is to re-check the coolant level the next day when the engine is cold, if the engine needs more coolant that's when to add it.
                    • Leif A.
                      • August 31, 1997
                      • 3654
                      Re: Cooling System
                      One additional question...my radiator has a 15# RC-26 cap and my supply tank has a 15# RC-15...are these the correct caps? Again, mine is a '67 L79 w A/C.
                      Leif
                      • Timothy B.
                        • April 30, 1983
                        • 5202
                        Re: Cooling System
                        Leif,
                        The radiator in the car can't be a original style Harrison radiator. There should only be a radiator cap on the supply/expansion tank and the RC-26 is the correct cap. Take a picture of the set up and post it so we can see what you have.
                        • Leif A.
                          • August 31, 1997
                          • 3654
                          Re: Cooling System
                          I'll get a picture posted ASAP...thanks, Tim.
                          Leif
                          • Leif A.
                            • August 31, 1997
                            • 3654
                            Re: Cooling System
                            Tim,
                            Let' see if I did this correctly...first attempt at loading and sending pics. Thanx.
                            Leif
                            • Leif A.
                              • August 31, 1997
                              • 3654
                              Re: Cooling System
                              A few more...
                              Leif
