C2 Dash cluster tab - NCRS Discussion Boards
C2 Dash cluster tab
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12693
    C2 Dash cluster tab
    Could someone post a photo of the right dash cluster tab on a C2 (where the screws holding the dash cluster screws into the clip)? Mine was broken off and I've built up some new fiber glass but I need to know how to cut of the glass to mimic what was originally there...
    Rob.
    NCRS Software Developer
  • Gary F.
    • August 29, 2010
    • 248
    Re: C2 Dash cluster tab
    Here's a couple from my 63 Coupe.
    • Dennis B.
      • May 31, 2004
      • 174
      Your Welcome Dennis
      • Rob M.
        NCRS IT Developer
        • January 1, 2004
        • 12693
        thanks both for the photo's, that should get me going...
        Rob.
        • Bob R.
          • June 30, 2002
          • 1595
          If you need better photos I have a 63 dash section without the pad on it in my basement and can send you photos.
          • Rob M.
            • April 30, 2003
            • 657
            Rob,
            I had the same problem. One tab was broken. I took a metal washer and placed it behind the broken tab so that the hole where the screw would go was close to correct (when the two were combined). I then scribed the washer at the point where the fiberglass had broken. Then I cut the washer and glassed it to the existing fiberglass tab (front and back). Finally, I drilled out the fiberglass and sanded it to match the other tabs. It worked great for me and I hope this helps.
            I have a couple of pictures, but have problems uploading pictures to our site. PM me and I'll be happy to send them to you.
            Rob
            '66 327/300 Regional Top Flt
            '08 6 speed coupe
            • Rob M.
              NCRS IT Developer
              • January 1, 2004
              • 12693
              Hi Bob,
              I think I'm ok with the photo's received so far... thanks for your offer!
              here is another one I received from Harry Sadlock:
              Rob.
