1967 '942 vs '351 Blocks (or VIN 7107262, Your Block *Might* Be on eBay!!) - NCRS Discussion Boards
  • Patrick B.
    • August 31, 1985
    • 1986
    Re: 1967 '942 vs '351 Blocks (or VIN 7107262, Your Block *Might* Be on eBay!!)
    4 bolt blocks also have relief cuts at the top of the bores for the intake valves and they have 2, 1/4-20 taped holes near the cam sprocket contact surface.
    I believe that all 3855962 blocks were 4 bolt and all 3855961 blocks were 2 bolt. All the other 396, 427 and 454 castings were machined in both 2 bolt and 4 bolt configurations.
      • 15573
      Originally posted by Tim Gilmore (16887)
      Two and four bolt main blocks were the same casting. You can convert a two bolt block to look like a 4 bolt block.
      Same for small blocks - in fact one doesn't have to do anything to a small block because there are NO external differences. For SB it is all in the machining after casting.
      • Kenneth B.
        • August 31, 1984
        • 2084
        TERRY TERRY I have people that swear that all 1970 SB corvette blocks were drilled 4 bolt mains. LOL
        • Patrick B.
          • August 31, 1985
          • 1986
          It is true that even 350-300 had 4 bolt blocks in 69 and 70.
          • Dick W.
            • 10483
            I have been told that you can do a little cosmetic work on the exterior of a two bolt block and it will look exactly like a four bolt, not that I know anything about it
            Dick Whittington
              • 15573
              And what about all the millions of other Chevrolet small block V8s out there that never were installed in a Corvette? Please do not take such a narrow view. If your Corvette was missing its engine, or if the engine suffered a fatality, the whole Chevrolet V8 world could be your donor.
              • Kenneth B.
                • August 31, 1984
                • 2084
                Guess I was wrong. I thought only the LT-1 & truck blocks were 4 bolt mains. And to think my Grandpa told me that in a bar so I was sure it was true.
                • Patrick B.
                  • August 31, 1985
                  • 1986
                  Should have asked your grandpa before he had been in the bar too long. Sorry if I stumbled into a private joke between you and Terry.
                  • Kenneth B.
                    • August 31, 1984
                    • 2084
                    #24
                    NA The more the merrier. Maybe if we were all setting in the bar with Grandpa we would have got the straight scoop.
                    • Pancho T.
                      • July 31, 1993
                      • 238
                      #25
                      About twenty years ago I had an original motor '66 390hp roadster that was built on either the last or second to last day of '66 production.It had "351" block in it that was dated G 9 6.So crazier things could have happened but that does seem too late for 942 block to be used in a '67
                      • Page C.
                        • January 31, 1979
                        • 802
                        #26
                        I agree with Richard Edgen in post #3 that this vin is 4262. This block came up in post back in Sept 2013 by Joe Marocco. I will try and attach the link. https://www.forums.ncrs.org/showthre...mping-question
