Flight Judging points deduction for missing A.I.R equipment on '67 BB.
Re: Flight Judging points deduction for missing A.I.R equipment on '67 BB.
Here are a couple of photos of a restored '67 427/400 with A.I.R.; the only bright spot is that the carburetors on a '67 3x2 don't change with A.I.R. (on a single 4-barrel L36, the carburetor IS different with A.I.R.).
DSC00017.JPG3x2K19RH.JPG- Top
Jim, Carbs are different, air cleaner base is different, Sun Air Wheels Booklet needed in glove box (obviously interior section), as Dan said the spacer, upper radiator hose, Smog bracket, tension bracket, check valves, mixture control valve, smog tubes, hoses, spacer on pump, Intake manifold is different, passenger side valve cover is different, vacuum line is different, and I think the vacuum advance is different as well.....ARA.Last edited by Michael W.; February 18, 2014, 05:21 PM.- Top
I maybe be wrong, but the thread indicates no AIR system, the judging sheets does not break anything down as per item It states only 10 for originality and 10 for condition, granted there is the plugs in manifolds and a missing belt. and a lot of maybes posted here.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Then back the exhaust manifolds for a question. I understand a configuration issue because of a correct manifold with plugs. But if the correct manifold is there, the A.I.R line item deduction would be less than 20 points?- Top
Jim, in short when the judging process finds something that is not typical due to your AIR system missing - Yes there is a deduction. The best way to find out what your up against is to have the car judged at the chapter level and then the owner will know where he stands. Its A great place to start with a car that the owner may want to take through the process. Like Mike Ward explains years ago when no one wanted the AIR system it was removed and generally there was no reason for someone to swap out valve covers, air cleaner bases, BBBUT there is about 50 years of tinkering under the hood so anything is possible.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
I maybe be wrong, but the thread indicates no AIR system, the judging sheets does not break anything down as per item It states only 10 for originality and 10 for condition, granted there is the plugs in manifolds and a missing belt. and a lot of maybes posted here.- Top
Mike, The only reason I say "maybe" is there is no car being judged here, And no way of really looking to see what else is really correct or incorrect. I took a look at the the on line judging sheets for the A.I.R. system it only gives 10 and 10 for the system, and what ever else is deemed incorrect because the system missing all of the componets. I don't know if the on line sheets for mech. 67 reflect any changes due to a newer edition.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
This is why we are a little confused. If the A.I.R. is a single line item, would there be additional deductions for say a non A.I.R carb bottom? If so, would that only be a 20% configuration issue? Then back the exhaust manifolds for a question. I understand a configuration issue because of a correct manifold with plugs. But if the correct manifold is there, the A.I.R line item deduction would be less than 20 points?- Top
Jim, an analogy would be judging added side pipes on a car. For example, the side exhaust pipes themselves would receive a deduction (if the judges determined the car was not a factory original side pipe car) BUT also the absence of the cutouts in the rear valance for the under car exhaust tips would also be a judged item also. Rockers are different for a pipe car versus under car exhaust, etc...So just one line item may affect other areas of the judging process. ARA
It's like a luggage rack, you don't deduct for the rack, you deduct for the holes and the missing paint.
Ara, what deduction would the side pipes receive? I can't think of one. It would be double dipping. At the last meet I judged at there was a 67 with add on side pipes. As I recall the total points deducted was about 200 when you added all 5 teams together.It's like a luggage rack, you don't deduct for the rack, you deduct for the holes and the missing paint.- Top
Harry, nice to hear from you. Off the top of my head the judges would look/judge the splash shields and presence or absence of weatherstripping on them, the cutouts on the body for the side pipes themselves, the correctness or lack thereof the rocker moldings, the rear valance correctness, the lack of ground straps on the frame for under car exhaust pipes, the cut at the front of the body on side pipe car/non side pipe car, possibly even the exhaust note difference on side pipe car versus under car exhaust system, etc... 200 points seems like a lot, but who knows....ARA
The 10/10 is just for the basics of the system, but there are LOTS of other components that are specific to A.I.R. and whose part numbers are different from those used on a non-A.I.R. car, starting with the basic engine assembly (different suffix, etc.) and continuing through items such as the distributor, carburetor, air cleaner, drive pulleys & belts, valve cover, hoses & plumbing, etc. All of those items add up, and are assessed individually in addition to the few items assigned the 10/10 in Section 11 on the judging sheet. As with other systems on the car, deductions depend on how much of the total system has been removed and is now "missing'.- Top
