Hey guys
First off, my car is a February 17th Build 67 Convertible, and the Column's Signal Switch cover is dated 043 7 (odd, that is a Sunday)
I am trying to get my arms around this steering column re-build, but, as ever, its full of surprises.
I have Jim Shea's Column Rebuild PDFs... and I am going through it slowly. I have my column apart... and have already hit some obstacles.
Here is a picture of what I am dealing with.
My column "appears" to be the late style, with the spacer and the clamp.
When I got it all apart, it had the lower bearing pictured above which I labeled as "5 early". The picture shows the exact parts that were on my column shaft in the order that they were in.
Jim's Column info, Paper 2 list that it should be (from steering box end):
18 Spacer, 17 "Packing", 16 Spring, not shown 7802124 Washer, 5 Lower Bearing Late, Not Shown 262474 Spring Seat, 21 Spring
Paragon has a schematic for the Late 67 Column as well
Here are my Questions
1) There should be #17 "Packing" between the spacer and the spring. What exactly is packing? Is there a part number for this? The spring seems to fit in a lip on the edge of the spacer... is that where "Packing" goes?
2) Do I have the Lower Bearing Labeled correctly? The one that came off the shaft is the one that I have marked 5 early.... the one I bought to replace it is the one in GM packing above, marked "5 Late", is that correct?
3) What I have labeled ?c... is that any of the things that Jim has marked in his PDF, or is it a broken part of a bearing or ?. To my eyes, it looks like a "spring stop", and 21 is resting against it... So is that the 262474 Spring Seat?
4) 2b... what part is that, in Jim's 67 Late Corvette Standard Steering Column Blowup pic?
5) I have a mysterious piece labeled ?a that is a black paper like ring that was floating around on the shaft... Have no idea what it is, or where it is supposed to go... any ideas?
6) Paragon list a 12355K Steering Column Lower Bearing Kit... how does that fit into the equation? Is it one of the items in Jim's Doc, with a different name?
Lastly... when assembling the column... which way is up? Or what is the top facing the sky? The shaft has two flat spots and the steering box end has a flat side... how should I "orient" it when butting it all together?
Thanks! VERY MUCH!
Thanks! VERY MUCH!
