63 wiper arm parts MIA - NCRS Discussion Boards
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12883
    I'm suspecting I'm missing parts in my wiper arm. Can the missing parts be bought somewhere or should I try to locate an original 63 left wiper arm somewhere??? Any tips or hints?
    Rob.
    NCRS Software Developer
  • David L.
    • July 31, 1980
    • 3310
    Re: 63 wiper arm parts MIA
    Rob,
    You are missing the pin and the part that connects the pin to the spring. I assume that these two small parts are the same used on other Trico wiper arms of the same era. Finding an original 63-65 Corvette L/S arm at a reasonable price might be difficult.
    Dave
      • 6960
      Rob, Is it possible to just drill a 1/8 hole through the wiper arm and install a roll pin in its place??
      • Rob M.
        NCRS IT Developer
        • January 1, 2004
        • 12883
        |I'm not sure if I need more then the pin? Does the spring attach directly to the pin?
        Rob.
          • 6960
          Rob, Yes there is a pin that runs across the lower pivot and holds tension on the spring. The problem is I believe the spring has a lot of tension and the pin spring has to be pulled and then the roll pin pushed through. This what I would do for a fix if it can be done. the only other choice is to purchase another blade. There is one company that makes a repro, Americas Finest Corvettes, to make correct you'll have to install the lower shield (The part that has the patent numbers wriiten all over it).
          • David L.
            • July 31, 1980
            • 3310
            There are 2 parts missing. The spring attaches to a connector which then attaches to the pin. I will post a photo when I get a chance.
            Dave
              • 6960
              Dave is correct I took a look at my 63 wiper and the appears to be a bracket that hooks around the pivot that spring attaches.
              • David L.
                • July 31, 1980
                • 3310
                The connector helps spread out the load from the spring to the pin, otherwise the pin would tend to bend if the spring was directly connected to it - simple structural analysis, a "point load" would tend to bend the pin. A "point load" on the small hole on the connector would only tend to elongate the hole.
                Photo #1 is from an original 1965 Chevelle wiper arm. Note that the lower part of the Chevelle wiper arm "flares out" unlike the Corvette wiper arm lower part.
                Photo #2 is an ANCO wiper arm which is similar in construction.
                Dave
                • Rob M.
                  NCRS IT Developer
                  • January 1, 2004
                  • 12883
                  Dave
                  Great pics, thanks for posting!
                  Rob.
                  • Bob R.
                    • June 30, 2002
                    • 1596
                    Americas Finest makes a pretty good reproduction of the original 63 wiper arm.
