63 master cylinder assembly - NCRS Discussion Boards
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12867
    Today I investigated my master cylinder parts to figure out how to assemble it all
    I had to figure out what the order of assembly would be and after studying the old parts bag I think it needs to be like this:
    Could someone check this out and let me know if this is indeed the right order (or otherwise what needs to be swapped)???
    Rob.
    NCRS Software Developer
  • Harry S.
    • July 31, 2002
    • 5344
    Re: 63 master cylinder assembly
    Wrong order, the rubber washer goes in first, then the spring, cup, piston and clip.
    • Rob M.
      NCRS IT Developer
      • January 1, 2004
      • 12867
      Thanks Harry for your feedback.
      So If I understand correctly I need to move the round rubber washer (item # 4, reading L to R) to the for right (so after the complete spring assembly) and then all is fine???
      Rob.
      • Harry S.
        • July 31, 2002
        • 5344
        Yes.
        And make sure there is no old one in there. The last MC I rebuild there were 3 at the bottom that I had to remove.
        • Rob M.
          NCRS IT Developer
          • January 1, 2004
          • 12867
          Photo received from Harry with corrected order:
          Rob.
