67 E-Brake Handle - NCRS Discussion Boards
67 E-Brake Handle
  • Ara G.
    • January 31, 2008
    • 1108
    Re: 67 E-Brake Handle
    Originally posted by Jeffrey Salz (13182)
    There are several differences between the early all black plastic and the 2 other "generations" of handle up to 1976. Below is a photo of all three with a top and side view of each. The one on the bottom is the latest hard plastic design. These are all unrestored originals that have been separated from their handles in preparation for replating and restoration. It may be hard to see but the diamond pattern stops short of the chrome tip by about 1/8" where the earlier black and chrome designs have the diamond right up to the chrome. The pattern itself is sharper in the earlier designs and the corners are sharper. The all black is manufactured differently in that it is essentially molded as one piece. The chromed ones have center core which is completely chromed and the sides are molded to this core. The core material is a grey ABS or polystyrene material as are the black sides. It is softened by lacquer thinner or acetone which generally indicates ABS. I have had hundreds of these sent to me over the yeas rand have never had an all black one from a '68 although it is entirely possible that they are out there.Jeff
    Jeff, GREAT picture. Thanks for posting. ARA
    • Timothy B.
      • April 30, 1983
      • 5202
      My 67 convertible is built B-23 in 1966 and this is the handle. It must be like Wayne say's, random between chrome and black.
      • Donald S.
        • August 31, 1996
        • 186
        #18
        Our '67 coupe built A-31 is even earlier than Tim's so don't think all the early cars had black handles. This is the before picture...Jeff did a great job putting the "sparkle" back on the chrome. Don
        • Al B.
          • January 29, 2014
          • 22
          #19
          Thanks Tim
          It seams odd the chevy would source different handle and use them in such a mixed fshion. My first 67 built in Feb 67 (vin 9749) had the chrome grip my current 67 (vin 2226) built on or about 30 Sept 66 has the all black handle. Others have a mix of them hard to know what should be in what car ! Oh well.
          Thanks for your help
          Al
          • Tim G.
            • March 1, 1990
            • 1417
            #20
            I have #1023 and it's a 22,000 mile car with a solid black handle.
            • Al B.
              • January 29, 2014
              • 22
              #21
              Tim
              Sounds like you found a great car, 22,000 miles - wow
              • Wayne W.
                • April 30, 1982
                • 3605
                #22
                The first few May have had all solid stainless handles. I dont know how many, but #5 certainly did. This was pilot stuff, and I dont know if it went over into regular production or not. Probably not.
                Originally posted by Al Burton (59508)
                Thanks Tim
                Al
                • Kenneth B.
                  • August 31, 1984
                  • 2091
                  #23
                  I believe that earl 67 corvette had an all black e-brake handle and at some point they added a chrome insert down the lenght of the handle and a ring around the push button end. My question is does any know when this change took place ? Mine has the all black handle and was built on or about 30 Sept 67, not sure if it wore off and should be chrome or should it be all black.Thanks for the helpAl Burton
                  My 2 1967'S VIN # 5564 & 8706 have black handles
                  • Al B.
                    • January 29, 2014
                    • 22
                    #24
                    Interesting - never came across a car that early in the build process. Just makes keeping them "as built" all the more Challenging.
                    • Peter L.
                      • May 31, 1983
                      • 1930
                      #25
                      Revisiting the 67 E-brake handle again. Our B22 build '67 coupe, S/N 1476, has the same E-brake handle with the chrome trim as Tim's '67 convertible. It's also worthwhile reviewing Noland Adams' book on the subject, p 389, & his research indicates that the two different '67 Corvette E-brake handles went in & out installation throughout of the production year. So, whichever E-brake handle you have in your '67 & you have no reason the think it has been replaced, it's most likely the original. Pete
                      • Al B.
                        • January 29, 2014
                        • 22
                        #26
                        Pete
                        Thanks for your input, ours has a build date of 26 Oct 66 VIN 2226. The handle looks to be original to the car (normal wear, etc), waiting on Noland's book to come too. My other 67 (VIN 9749) had the chrome handle. Always liked the look of the chrome but would not change it. Thanks again. Al
                        • Steven B.
                          • April 11, 2012
                          • 233
                          #27
                          My 67 June 23rd coupe handle is all black. Were these just in time parts from different suppliers? There doesn't seem to be much consistency.
                          Steve
                            Steve
                            My June 8th car also has the black handle. There was no such thing as "just-in-time" delivery in 1967, which is why material was stacked to the ceiling as "just-in-case" inventory. As indicated in the '67 JG, either version is acceptable.
                            • John C.
                              • March 1, 1986
                              • 37
                              #29
                              This is a pretty old thread regarding 67 parking brake handles. My late 67 came with an extra OEM parking brake assembly. The OEM box has a build date of 3/22/95 and a Corvette Central PN 193020 and says 67-82. The newer CC catalog shows the same PN that fits only 71-82 cars? Confused by what I have?
                              John 9790
                              You do not have permission to view this gallery.
                              This gallery has 4 photos.
                                • 43277
                                #30
                                John 9790
                                John------
                                The parking brake handle assembly shown is not correct for a 1967 but it will SERVICE a 1967. This handle, GM #14033719, was used in PRODUCTION for about 1980-82 but became SERVICE for 1967-79 when the original levers were discontinued. It will function perfectly for your application. In fact, the plastic portion of the handle is much more durable and breakage-resistant than the original handle plastic which were polystyrene.
