57 Emergency Brake Flasher Bracket - NCRS Discussion Boards
  • Edward C.
    • August 31, 1993
    • 27
    Attached is a picture of my Emergency Brake Bracket. It is labeled John W. Hobbs Corporation Springfield IL.
    It fits on my 57 OK but the relief for the EM Brake pin is on the right side, thus causing a collision between the pin on the EM Brake rod and the bracket when releasing the brake (relief needs to be on the left side). Can anyone tell me what this is for or where I can find a correct unit for my car? Thanks.
    Ed
    (23262)
  • Gary C.
    Administrator
    • October 1, 1982
    • 17675
    Re: 57 Emergency Brake Flasher Bracket
    Ed, IIRC the Passenger car mounted opposite of a Corvette. Gary....
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Dan P.
      • December 1, 1990
      • 683
      hope this helps
      Last edited by Gary C.; February 10, 2014, 09:44 AM. Reason: added photo per Dan Patch's request
      • Edward C.
        • August 31, 1993
        • 27
        Perfect! Thanks Dan, I knew the answer was out there somewhere. Now if I can just locate the correct one.
        • Gary C.
          Administrator
          • October 1, 1982
          • 17675
          Ed,
          I have both emergency flasher brackets. I can't see why you couldn't cut the vertical tang off of one end on the non-Corvette bracket and weld it onto the opposite end. After comparing it looks to me like that would work.
          Might be worth a try if a non-Corvette bracket could be bought cheap enough. JMTCW,
          Gary
          NCRS Texas Chapter
          • Edward C.
            • August 31, 1993
            • 27
            I am considering doing that if one doesn't turn up soon. Let me know if you run across one, I'll be happy to buy it from you, I'm ready for this issue to be behind me. Thanks for giving this your consideration.
            • Gary C.
              Administrator
              • October 1, 1982
              • 17675
              Ed,
              The simplest option is to find a plug for the speedometer flasher light hole and forget about the emergency brake flasher.
              I've not see a Corvette emergency brake flasher bracket for sale in years.
              Gary
              NCRS Texas Chapter
              • Mike E.
                • February 28, 1975
                • 5138
                Ed,
                sent you an email.
                Mike
                • Bruce B.
                  • May 31, 1996
                  • 2930
                  I took a passenger car bracket, cut it apart and welded it back in the correct configuration.
                  The change is undetectable.
